tracker gearing??
  • 1658 Views
Offline Tracker-Kid
  • 50
tracker gearing??
« on: July 17, 2008, 05:38:29 PM »
hey guys just got one Question? can you put gears in the t case in a 94 4x4 tracker that has 3 speed auto??  just want to gear down the low end? ???   thanks guys
        Mikka
IF ITS BROKEN.....  WELD IT!!
Re: tracker gearing??
« Reply #1 on: July 17, 2008, 05:44:23 PM »
Yes, they are available from several vendors, between 600 and 800 last
I checked. This will only lower low range, not high range.
« Reply #2 on: July 17, 2008, 06:29:43 PM »
To drop the range in high range you need to change the gears in the diff.  Since you have an auto you can get the gears from a manual rig easily enough.  There was a post a while back that gave every model and what range it had in it.  :)
« Reply #3 on: July 18, 2008, 02:39:03 AM »
Or, go kicker 3 (samurai t-case behind your t-case) for 1.4 (40%) reduction.
