transmission noise/vibrating...
  • 8 Replies
  • 2389 Views
« on: June 15, 2012, 11:12:38 AM »
Ok on my 86 sami I started having trans problems. It makes alot of whining noise during acceleration which i think could be the syncros. But today while im not accelerating the trans vibrates violently and  becomes very loud. it feels like when you are in 4H at a decent speed and let off the gas and coast, but I am not in 4wd. I also had a problem getting back into 2wd after being in 4L for a few mins. I have the transfer case shift fix from rocky so not sure whats going on.
Re: transmission noise/vibrating...
« Reply #1 on: June 15, 2012, 03:15:14 PM »
The synchos won't whine, that will be a bearing somewhere or lack of lubrication, the vibration can have several sources, bad UJs, or if the vehicle is lifted or springs are tired, incorrect pinion angle.
« Reply #2 on: June 15, 2012, 07:02:44 PM »
well after 3 shops I still dont have the right rear oil seal for the trans. but when i took the drive shaft off the trans i found the bolts were loose. so maybe when i get it back together it will stop
Offline lv2fsh
  • 312
  • 19
« Reply #3 on: June 15, 2012, 08:45:22 PM »
Loose bolts will make a terrible racket. I got my last seal at O'reillys. It was thinner but the shaft and outside was the same.
« Reply #4 on: June 16, 2012, 03:29:40 PM »
well i tightened the bolts but the t-cases still violently shakes.... everything is lined up and tight. any ideas? and to top it off a hod latch broke while doing 40 dented my hood and damn near broke my windshield....and may have made me pee a little bit
Offline lv2fsh
  • 312
  • 19
« Reply #5 on: June 16, 2012, 09:35:14 PM »
Probably a bad U-joint or broken T case mount. or trans mount.
« Reply #6 on: June 17, 2012, 01:15:52 PM »
You are right. The ujoint I just replaced went out. I'm getting a new drive shaft the one I have is damaged so I've gone through 2 ujoints in a month.
Offline justzukies
  • 88
« Reply #7 on: June 18, 2012, 07:26:52 PM »
Hood in the face huh.  I always wondered what that would be like.  Better to read about it.
94 kick 1.6 16V AT 4dr  Calmini 3" lift
« Reply #8 on: June 18, 2012, 09:19:07 PM »
 :D yeah it defiantly woke me up! If you get hood latches dont go cheap....you might make skid marks on more than just the road.  ::)
