transmission problem
  • 1693 Views
Offline brace
  • 264
  • I built it; I break it; I fix it.
« on: June 28, 2004, 05:57:09 AM »
When I bought the transmission from the junk yard the wires were cut.  I disconnect the ones off my bad transmission, but the wires on the most forward of the two were broken by me during removal.  Does it matter how I connect the wires?
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Offline jagular7
  • 1026
  • Jagular7
Re: transmission problem
« Reply #1 on: June 28, 2004, 06:32:16 AM »
Probably. I think it has to do with 5th gear and reverse. The Sami runs a little different in 5th gear or something like that.
I have a junk trans (doesn't spin at all) from an old Sami I once had (should have kept). I'll see if the sensors are on it.
Lenexa, KS
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #2 on: June 28, 2004, 06:34:43 AM »
One of those plugs are for the EGR valve when you put the truck in fifth gear.
