35's on a sammi... Gears?
  • 9 Replies
  • 2079 Views
Offline Real_Red_Sammi
  • 43
  • Make it hurt!
« on: June 25, 2004, 04:12:27 PM »
With 35 12.5's on my sammi, will I have to change the gears out if I want to move? Or will it go ok.
"I do what I want"
LMS wasted my time
Offline 1bigtracker
  • 3409
Re: 35's on a sammi... Gears?
« Reply #1 on: June 25, 2004, 04:24:32 PM »
oh it will move. have you ever rode a rideing lawn mower? ;D  here is a gear calc. to help you.
http://www.izook.com/tech/math/gearcalc.htm
stu
Offline shoyrtt
  • 161
« Reply #2 on: June 25, 2004, 04:35:43 PM »
I think I made into 3rd once (in the flats) 4th down hill :P
4-Low was a joke.  Rock Crawling was more like Rock Bonzi :o
GET GEARS!
Offline idaholwb
  • 772
« Reply #3 on: June 25, 2004, 07:42:40 PM »
 I have a 1.6 8v with a kick trans, kicker3 which does nothing for the highway, a stock sammy case, and 5.12s. My speedo is accurate, and I can do 75-80 down the freeway with about 18mpg with a Weber and a 1.3 intake. I ought to get much better when I'm done with the 16v 1.6 swap.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline trialspro
  • 149
  • 1984 suzuki sj410 lwb, spoa... rusty
« Reply #4 on: June 25, 2004, 08:32:39 PM »
whats best, geared t-case, or gears in the diffs?
or is it all about pricing...?
Andrew
Offline zooky
  • 135
« Reply #5 on: June 25, 2004, 10:20:05 PM »
I have the Kicker3 also, ain't it sweet! Are you going to gear down the sami case? I have 4.16's in mine which makes low-low really nice.
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #6 on: June 25, 2004, 10:43:17 PM »
Well, let me dive into this. The big question is what do you intend to use your Samurai for. Rocks, mud, highway, or Mall Cruiser ;D A samurai has a 1.3 litre motor that is a great motor if treated correctly. That means that it really doesn't care for 35 inch tires.  :-/ It only has around 64 hp so I think you can see where I am going.
T-case gears are a wonderful thing but all of them are not created equal. So many claim 6:1, 6.5:1 and 8:1 but this is all 4 lo reduction. You also need to look at the high gear reduction. Rocky Road Outfitters t-case gears offer the lowest hi range reduction on the market. Their 6:1 and 8:1 gear sets offer 24% hi range reduction and this reduction is almost perfect to correct for a 33 inch tire but it is no where near enough for a 35 inch tire (unless you stay in 3rd and 4th gear) So to answer your question t-case gears alone will not help you out for road use but will get you crawling on the trails in no time flat.
R&P gears are a great solution for correcting road speed but they do little in the lo range crawlability arena. A 5.38 R&P setup is spot on for 35 inch tires and will get your road speeds almost back to the stock ratio/speed. But it doesn't help in 4lo much at all.
I think your best solution would be to put in some 4:57 R&P gears and grab a 6:1 t-case from RRO and hit the trails. This will give you excellent roadability and a super sweet off-road crawlability.
Disclaimer: I have a Samurai with 35" Boggers and I have run all the combos mentioned above in my own vehicle ;) I do have a 1.6 litre motor with efi though :-/
www.Zuwharrie.com[/url]
Offline idaholwb
  • 772
« Reply #7 on: June 26, 2004, 04:01:49 AM »
No, I'm keeping the sammy stock. It works very well in high range. It would be nice to find a slightly lower gear kit for the kicker. Maybe somewhere around 2.5-3.5:1. I don't want to go as low as the Calmini 4.24:1s, I think that is overkill in a lot of ways.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #8 on: June 26, 2004, 06:33:43 AM »
real red sammi is my brother he also forgot to mention we just finished putting a 1.6 8v in place of the 1.3 :D we don't do much rockcrawling mainly just mudded up sippi holes and a few creeks ;D there's not a whole lot of rocks up this way. what are the stock r&p gears in the sammi we know all about tracks and kicks but not a whole lot about sammi's its a 91 sammuri JL
At Lakeview Motorsports, were wasting your time already!
Offline idaholwb
  • 772
« Reply #9 on: June 26, 2004, 12:23:25 PM »
 Samurais use 3.73s in the diffs, but they also have a 1.4:1 reduction in high. I translates into 5.22:1 in high.
Similar to the manual kick having 5.12s.
97 Sport
265/70-16s
2" lift
2.0 swap
