Twin webbers
  • 9 Replies
  • 2911 Views
Twin webbers
« on: December 08, 2003, 11:14:45 PM »
Has anyone got any pics of the twin sidedraught Weber set up in a Track/Kick. I was thinking of using the manifold with a couple of the twin injector bodies but am concerned about clearance as I have the brake servo and steering shaft on that side.
  • 6589
Re: Twin webbers
« Reply #1 on: December 09, 2003, 12:23:11 AM »
I know this isn't exactly what you're looking for but I think it will give you enough information to figure out if it'll work.
http://www.zukiworld.com/month_060101/feature_reynolds_01.htm
has a couple engine bay pics in a Samurai..
Offline Speedracer7c
  • 2210
Re: Twin webbers
« Reply #2 on: December 09, 2003, 12:47:44 AM »
They have a picture on calmini's website http://www.puresuzuki.com/40mm_sidedraft21.htm hope this helps. Andrew
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: Twin webbers
« Reply #3 on: December 09, 2003, 04:44:39 PM »
I have the same engine from Reynolds and the dual sidedrafts. I went back to stock carb for now due to the poor performance of the carbs. I wasn't able to get them to idle down and they would dump so much fuel it would flow out the velocity stacks. At the time I didn't have time to play and tune them so I threw the stocker back on. Do you have any suggestions to try when I put them back on. I did check float level. The floats are the plastic style not brass. I was running at 3psi of fuel. I was thinking of getting new needles and seats and floats too.
Let me know what you think.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline Mike71
  • 1449
Re: Twin webbers
« Reply #4 on: December 09, 2003, 04:53:46 PM »
what is the rubber hose coming out of the chrome caps over the air filter?
623hp kb cobra sold! 100hp kick new DD :P
  • 6589
Re: Twin webbers
« Reply #5 on: December 10, 2003, 01:04:08 AM »
Please read this article, it may help with your carbs...
http://www.zukiworld.com/month_050102/feature_dcoesetup.htm
If that doesn't work for you, I'd be interested in buying your setup...
  • 6589
Re: Twin webbers
« Reply #6 on: December 10, 2003, 01:05:53 AM »
That's where the breather comes in from the valve cover. I didn't want a oily gooey engine compartment.
Offline 87BlackSami
  • 191
Re: Twin webbers
« Reply #7 on: December 10, 2003, 11:58:50 AM »
Damn your good. This might doit. I'll let you know ether way.
Offline Mike71
  • 1449
Re: Twin webbers
« Reply #8 on: December 10, 2003, 12:29:46 PM »
why is there a breather on the carb? doesnt it suck in air in where the filter is exposed?
  • 6589
Re: Twin webbers
« Reply #9 on: December 11, 2003, 12:35:06 AM »
I don't understand your question. Those two tubes go from the breather hole in the top of the valve cover to the inside of the filter area going into the carbs.
