Using 1.6 head on a 1.3 block
  • 18 Replies
  • 10390 Views
0 Members and 31 Guests are viewing this topic.
Offline timmy0321
« on: August 22, 2006, 05:53:13 PM »
whats up everyone,
    I have been working on my 87` samurai and want to put a 1.6 head on my 1.3 block...  Can that be done or is it better to just drop the whole 1.6L in with the EFI.   Also I have a new cam and headers for my 1.3 and was wondering if I put the 1.6L head in will the can and header fit?  Hope for some help here...  any other tips will be greatly appriciated.  aloha from hawaii
           timmy
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: Using 1.6 head on a 1.3 block
« Reply #1 on: August 22, 2006, 06:03:21 PM »
i know some guy's that used a 1,3 top on the 1,6, so it should go the other way also.
but a 1,6 is a more potent engine, dont know if the exhaust fit
Offline SamuraiGuy7
  • 80
  • My Samurai
« Reply #2 on: August 22, 2006, 06:11:15 PM »
1.6 header fits a 1.3 and visa versa...heads are the same way...you will have less low end torque with a 1.6 head, but better top end... a 1.3 head on a 1.6 gives you better low end torque, worse top end speed... cam should fit, not 100%.
Taylor
87 Samurai
     4x4
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
« Reply #3 on: August 22, 2006, 08:18:50 PM »
your better off putting in either a swift gt motor or the 1.6l motor
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #4 on: August 22, 2006, 08:32:26 PM »
keep in mind that the 1,6 engine is 1" taller than the 1,3. ;)
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
« Reply #5 on: August 22, 2006, 09:08:12 PM »
also don't forget that the 1.3 head has the fuel pump in it, and the 1.6 does not.  So, you'll be needing a new fuel pump of some sort.
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
  • 238
« Reply #6 on: August 22, 2006, 09:35:15 PM »
heres a link to a guy who swapped in the swift gt motor(1.3l DOHC) into a sammi....
http://www.teamswift.net/viewtopic.php?t=19766
and heres one of a guy who did the 1.3l head swap on a 1.6l block and dropped it in a sammi...
http://www.xfaktor.net/Projects/Suzuki/1600dohc/1600dohc.html
« Reply #7 on: August 23, 2006, 04:49:13 AM »
Headers will bolt on but the 1.6 has bigger ports than a 1.3 so you may lose some of the benefit. 1.3 camshaft may not fit a 1.6, there is a difference in length between some models, even if it does you need to check that there will be a performance gain over the stock 1.6 cam. The 1.3 carb is very restrictive on a stock 1.3 so you may not get any big performance gains without changing to a bigger carb, 1.6 inlet and manifold also has bigger ports.
UK carb model 1.6s have a fuel pump on the head  ;D
James
(Currently fitting a 1.6 into an SJ413K)
Offline purevil71
  • 261
« Reply #8 on: August 23, 2006, 10:41:26 AM »
I'm doing the 1.6 8V with the 1.3 head and intake in my rig as soon as:
#1. my current motor dies (which that's probably not likely..lol)
#2. the summer wheeling seasion is over
88.5 Samurai
I-Zook Staff
  • 238
« Reply #9 on: August 23, 2006, 10:56:02 AM »
plan on swapping in the 16v pistons from a 1.6l 16v into the 8v block if the 1.3l head is 16v
« Last Edit: August 23, 2006, 10:57:46 AM by droppedtracker »
  • 238
« Reply #11 on: August 23, 2006, 12:59:37 PM »
http://www.teamswift.net/viewtopic.php?t=10938
G13BB engine is the same as the Jimny, with the EFI it makes 80bhp - same as a 1.6 8V. Downside is that it is higher revving with less torque and max torque around 1000rpm further up the rev range. G13BB head on a 1.6 should be pretty good, I'd like to that to the Jimny eventually but the stock engine only has around 30k on it.
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #12 on: August 23, 2006, 02:25:04 PM »
that sounds like it whould be a badass Jimny! ;D
i think it's sad there is so little jimny talk here :'(
  • 238
« Reply #13 on: August 23, 2006, 05:33:33 PM »
a stock G13B makes 100hp not 80. putting the G13B head on a 1.6l 16v block will give it more torque, turbo it will make it a torque monster!
« Reply #14 on: August 23, 2006, 07:31:06 PM »
Thats cause CSR killed Suzui america.  :P
