Using 1.6 head on a 1.3 block
  • 18 Replies
  • 10402 Views
0 Members and 31 Guests are viewing this topic.
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
Re: Using 1.6 head on a 1.3 block
« Reply #15 on: August 23, 2006, 07:50:58 PM »
 :-[  what's CSR?  :-[
« Reply #16 on: August 24, 2006, 12:13:46 AM »
The Enemy >:(
The Mag that lied about easy Samurai rollovers
« Reply #17 on: August 24, 2006, 04:51:57 AM »
http://www.teamswift.net/viewtopic.php?t=10938
G13BB engine is the same as the Jimny, with the EFI it makes 80bhp - same as a 1.6 8V. Downside is that it is higher revving with less torque and max torque around 1000rpm further up the rev range. G13BB head on a 1.6 should be pretty good, I'd like to that to the Jimny eventually but the stock engine only has around 30k on it.
a stock G13B makes 100hp not 80. putting the G13B head on a 1.6l 16v block will give it more torque, turbo it will make it a torque monster!
If you follow the link, the last post is talking about the G13BB engine
Offline Andy89
« Reply #18 on: August 25, 2006, 05:03:48 AM »
The heads do interchange, including the cams.
The stock 1.6 cam is a good upgrade for the 1.3, with about 10 degrees more duration, and .5mm more lift.
The 1.6 head has bigger valves. .5mm int/2.5mm exh.
Its a good idea if you are looking for more power.
If you can, resurface it for more compression, .5-1mm.
