will 31's fit w/ 2in. lift on 87 sammy ?
  • 1069 Views
Offline MIDZUKI
  • 17
  • "if it breaks, just put some more weld on it"
« on: December 18, 2005, 08:38:40 PM »
I have an 87 sammy and wondering if 31's would clear with 2 inch shackle reverse lift ? i have the front bumper  off and the side tubes cut off.
87 zuk, locked, geared, mightykong, 33's
Offline sj416 nz
  • 38
Re: will 31's fit w/ 2in. lift on 87 sammy ?
« Reply #1 on: December 18, 2005, 10:24:47 PM »
shouled be able to make the tyres fit.
may need to get the hammer out so it dose not hit
at full flex
86 sj413
1.6 16 valve
5.14 t-case
32" simexs
airtec snorkel RRO coil kit toyota running gear 4.88
Offline ZeusZuki
  • 411
« Reply #2 on: December 19, 2005, 12:08:25 AM »
Hi Midzuki,
31's will fit but they will hit on the wheel well unless you do the following:
Put extended bump stops on to limit up travel or maybe a 2" body lift. You will have to work out the best wheel offset too. And like SJ416 said - maybe a little guard "adjustment" ;)
I believe that the 2" reverse shackle kit will make wheel rub even worse because the wheel now moves backwards and not forwards like a standard setup - they are a really good kit though so do not be put off by a little extra work to get things to fit.
I have done it on a SJ413 that had only a 2" lift but I had to run the right wheel offset and the tyres still rubbed - just.
Good luck ;D
Offline MIDZUKI
  • 17
« Reply #3 on: December 19, 2005, 10:03:19 AM »
Thanks i forgot to mention that i also have a 1 inch body lift also. What back spaced wheels would you recommend. and i am not afraid of a sawzall.
