Intermediate drive shaft removal
  • 1 Replies
  • 1827 Views
Offline TomU
« on: November 25, 2017, 07:51:59 AM »
My 87 Sami developed a vibration that worsened pretty quickly.  I checked for broken motor mounts, running gear supports and the driveline and found the universal joint at the transmission end of the intermediate shaft is shot.
I can see that it bolts to the flange where it attaches to the transfer case.  Searching the Net it looks like the other end is a splined shaft that slip fits into the rear of the transmission.  If that's true then it should be pretty easy to remove, fix and replace.
This is a new vehicle to me so before I screw something up I thought I'd ask if I'm missing something or if there is a gotcha doing this removal and reinsertion.
Thanks in advance,
Tom
  • 6602
  • 69
Re: Intermediate drive shaft removal
« Reply #1 on: November 26, 2017, 07:10:32 AM »
Yep, remove the 4 bolts at the t-case flange, drop axle down and slide out of transmission slip yoke.
There may be oil that wants to come out of the transmission when you do this.
