What Carb should i use
  • 2114 Views
« on: August 18, 2008, 07:36:47 PM »
Hello everyone,
I recently purchase an 87 Sami, and am rebuilding the engine.  I was wondering if anyone had any suggestions on what type of carb i should run and if you a running a specific type how do you like it.
Re: What Carb should i use
« Reply #1 on: August 18, 2008, 09:32:23 PM »
Im running a toyota corolla carb seems to work will. Just took it on a run and worked assume. It comes on 74-78 1200 corollas. Slight mods to spacer plate because primary hole slightly larger.Pretty much bolt on hook up all vac. lines idle solenoid. Looks aimost stock.Even pasted smog with it.Good luck with your choice.
Offline Amilla
  • 1076
« Reply #2 on: August 19, 2008, 10:02:10 AM »
A lot of people have been liking side draft carbs.
theres a couple vendors producing them now, not smog legal.  But i have heard that it is quite the boost in power, and no more stalling out at steep angles.
Amilla
Offline ROSS
  • 1412
« Reply #3 on: August 19, 2008, 12:16:33 PM »
two words
FUEL INJECTION
phloop
« Reply #4 on: August 19, 2008, 08:27:54 PM »
Two more words MySide or MySide2. Check out http://www.zuksoffroad.net/samurai_engine.htm
« Reply #5 on: August 20, 2008, 09:59:07 AM »
gotpropane.com
WAY simple system.
