What gasket do I need between the manifold and cat converter?
  • 1713 Views
Offline keith
  • 1176
« on: February 03, 2006, 07:41:20 PM »
What type of gasket goes between the exhaust manifold and the catalytic converter?  At Autozone they said a donought type on went in there.  I don't think that is correct because the downpipe is two pipes at the top that go into one.  Also I seem to see remnants of a flat gasket on the truck.  I have an exhaust leak in that area and can see that the gasket is broken.  Also I was missing 1 bolt and another was very loose.  Is there anything special about those bolts or can I get them at a hardware store?  Thanks.
Offline da_tub
  • 307
Re: What gasket do I need between the manifold and cat converter?
« Reply #1 on: February 03, 2006, 09:59:28 PM »
nope don't think there's anything special abouthem, and i belive your right about the flat gasket part..
91 four door ,and some stuff
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #2 on: February 03, 2006, 10:10:04 PM »
yes you need a twin pipe gasket, if I remember correctly it also fits VW's also
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline karl214
  • 228
  • I love YaBB 1G - SP1!
« Reply #3 on: February 04, 2006, 02:53:18 AM »
Autozone calls them a packing gasket...  ;D
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
« Reply #4 on: February 04, 2006, 08:19:20 AM »
Get Stainless bolts and nuts,
this way you will get them off
again, regular hardware will
corrode on perminent
Offline keith
  • 1176
« Reply #5 on: February 04, 2006, 10:52:50 AM »
Advance Auto had the gasket I needed.  It was $2.00!  Now I'm back on the road.  Advance Auto had a much better setup for finding parts than AutoZone did, plus the had the gasket in stock.
