What gasket do I need between the manifold and cat converter?
keith
1176
3
February 03, 2006, 07:41:20 PM »
What type of gasket goes between the exhaust manifold and the catalytic converter? At Autozone they said a donought type on went in there. I don't think that is correct because the downpipe is two pipes at the top that go into one. Also I seem to see remnants of a flat gasket on the truck. I have an exhaust leak in that area and can see that the gasket is broken. Also I was missing 1 bolt and another was very loose. Is there anything special about those bolts or can I get them at a hardware store? Thanks.
da_tub
307
oops...can we still back up>?
Re: What gasket do I need between the manifold and cat converter?
February 03, 2006, 09:59:28 PM »
nope don't think there's anything special abouthem, and i belive your right about the flat gasket part..
91 four door ,and some stuff
biker
730
7
It's a sickness I tell ya
February 03, 2006, 10:10:04 PM »
yes you need a twin pipe gasket, if I remember correctly it also fits VW's also
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
karl214
228
I love YaBB 1G - SP1!
Reply #3 on:
February 04, 2006, 02:53:18 AM »
Autozone calls them a packing gasket...
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
wildgoody
8134
67
Reply #4 on:
February 04, 2006, 08:19:20 AM »
Get Stainless bolts and nuts,
this way you will get them off
again, regular hardware will
corrode on perminent
keith
1176
3
Reply #5 on:
February 04, 2006, 10:52:50 AM »
Advance Auto had the gasket I needed. It was $2.00! Now I'm back on the road. Advance Auto had a much better setup for finding parts than AutoZone did, plus the had the gasket in stock.
