What to replace the front speakers with?
  • 17 Replies
  • 4797 Views
Offline echojeff
  • 414
  • Lo que sea
« on: January 07, 2007, 11:36:14 AM »
I have a Alpine CD stereo that came with my kick, but I did not use it much because the CD would skip on my dirt road and on other bumps.   I won a video Ipod in a drawing, and I got a transmitter for it, and I can listen to my tunes without skipping.  Problem is,  now I noticed how poor the original speakers sound.  :(  I have some 6X9's That I have had for a long but they have never been installed in anything before,  they should do good for the back.  What about the front?  I dont want to spend a lot, and save up for mechanical improvements,  I think it would not take much for the sound to be better than the speakers that are there.    Would it be better to relocate the front speakers to the front bottom of the door?  How about speaker wire?  Does it need to be replaced?  I will not be running a lot of power,  I think the stereo is 45watts X 4 channels.
Any suggestions?  I know all you younger guys are more into the audio aspects of these rigs than me.
Jeff
95 Kick 4dr JLX.
Offline urbanwheeler
  • 696
Re: What to replace the front speakers with?
« Reply #1 on: January 07, 2007, 09:22:25 PM »
Mine has some pioneer speakers from what I am guessing is the early 1990s. They still sound pretty good, and are made in japan(which is what tells me they are fairly old)
« Reply #2 on: January 08, 2007, 04:46:05 AM »
I replaced my stock front speakers with some better quality ones. They are a standard size (4"?) so it was an easy upgrade.
Online RJkick
  • 632
« Reply #3 on: January 08, 2007, 12:18:57 PM »
Check out   http://www.crutchfield.com/
They are pretty good and will answer the tough audio questions
Offline fullsink18
  • 250
  • Wheel Me!
« Reply #4 on: January 08, 2007, 12:24:42 PM »
Crutchfield is have a sale on 4" blankput speakers
94 2dr kick 8v
-     Full set of Calmini's skid plates, calmini header and full exhaust, k&n filter, sky idler arm, calmini idler arm brace and truss with stabalizer, lock-rite rear locker, Calmini 3"  BL, 2" Digger Spacers, Shrockworks bumper, chicago electric 8,000lb winch, 31" Grabber AT2, 15x7 2
Offline skandy32
  • 93
  • Zukiworld Rocks!
    • Andy Colver Photography
« Reply #5 on: January 08, 2007, 02:27:33 PM »
The front speakers is the first thing i replaced after i upgraded my headunit. I'm usin Alpine 4" / 10cm ( i think) speakers... at RMS they're 25w, but max at 45/50w. They sound pretty awesome, and cope with the top of the range Alpine headunit i brought for it.
they cost me about £25, so i suppose like $45 to you guys, and got them from www.caraudiosecurity.com
linky here - http://caraudiosecurity.com/shop/product/products_id/504.html
UK Vitara - 2" spring/shock spacers, 3" calmini body lift, 32x11.5x15" BFG MTs, rear half calmini exhaust/no cat, full Alpine ICE
http://www.andycolver.co.uk
Offline Sabercat
  • 42
« Reply #6 on: January 08, 2007, 03:16:20 PM »
The doors don't look very deep for mounting speakers and the pockets on the door panels seem to be in the way.I've been thinking about the same thing but haven't pulled the trim panels or gotten the measuring tape out yet.
Offline Carnage
  • 2453
« Reply #7 on: January 08, 2007, 04:11:22 PM »
replace the stock with aftermarket
and add an amp, sub, and possibly some tweeters if you like (really) clean highs
stock wiring should be alright
amp kit should be around 10 gauge for a basic system
heres what i have
Offline poorboy
  • 29
  • When in doubt... beat it out
« Reply #8 on: January 08, 2007, 04:15:49 PM »
mine have newer pioneer speakers in the front.
i wouldnt put any speakers in the doors because they are not sealed so water can get to the speakers.
i have heard that a 5 inch round speaker can fit in the front but i havent takent the covers off since to see if it is actually true or not
in my sidekick i have the two 4 inche pioneers in front and two pioneer 6.5 in the back side panels.  then i put two lightning audio 6x9s in boxes behind the rear seat.
it sounds pretty good like that. but i want to cut two new holes in the panel that the seatbelt comes out of and put two more 6.5s in there to see what it would sound like
That sh*t'll be alright
Offline Sabercat
  • 42
« Reply #9 on: January 09, 2007, 01:28:43 PM »
I measured in the door panel and there is only 2" of clearance in there.My speakers are pretty compact but still need 2.25" at least. :(
Offline R.Cadett.
  • 106
« Reply #10 on: January 09, 2007, 05:39:03 PM »
i have small 4" clarions that the previous owners put it, they sound pretty decent, but i relocated them to the inside of the console. where the plastics meet the floor, the cone fit right in there and i just screwed it right to the plastics heres where im talking about. this isnt my car, i have no pics of my interior.
95 Completely Stock Sidekick, i added fog lights , and thats about it
4x4tracker
« Reply #11 on: January 09, 2007, 07:45:27 PM »
I just got the 4"  blaupunkt speakers from Crutchfield they sound great
Offline costa 05
  • 206
« Reply #12 on: January 09, 2007, 07:57:22 PM »
I just put a 180 watt chinese unit in the sammi . The cool thing is in can use an ipod, a memory card, or a thumb drive. I plan on using a box that I bought at walmart $10 but will probaply sound like crap but the box I can use if need be and throw some alpines or jvc or pioneers in it about $25 a piece
when in doubt gas it!!
Offline echojeff
  • 414
  • Lo que sea
« Reply #13 on: January 09, 2007, 09:22:28 PM »
I just looked at the web site and it did not list those speakers for the front.  Do you know why?
95 Kick 4dr JLX.
4x4tracker
« Reply #14 on: January 10, 2007, 10:11:24 PM »
no i dont... Maby the tweeter will hit the plastic cover in the front and not the back?
