what do i do when im putting a ford 9"
trizacker
37
Every Cowboy needs a SIDEKICK!!
May 09, 2005, 05:19:07 AM »
when i put a ford 9 " rear end in my tracker. how do i do it? and do i need to put 5:13's in it as well ? And how do i set it up as well.
Mikerpm4x4
2875
12
Redline... all the time!
Re: what do i do when im putting a ford 9"
May 09, 2005, 09:58:13 AM »
Are you having a problem with the stock axle? If your just breaking the shafts then it would be cheaper to just buy a set if Calmini shafts. They were not availible when I did the nine inch swap. Here is a writeup on the Nine inch install.
http://www.zukiworld.com/month_070103/feature_hagen_ford9inch.htm
mike
Natebert
1098
May 09, 2005, 10:04:12 AM »
Thats such a good write up!
Thanks Mike!
~Nate
Mikerpm4x4
2875
12
Reply #3 on:
May 09, 2005, 10:06:47 AM »
Thanks Mike!
~Nate
:-[Thanks
;)Mike
