while the engines out...
  • 1262 Views
Offline trailtracker
  • 44
  • the fixing/modification is endless!
« on: February 27, 2006, 02:57:03 PM »
is there anything i should do? Anything you i can do in my garage to add a little more performance to the 16v tracker engine? any maintenance that i can do easier now? trannys out too.... by the way, would anyone know where i could get two transmission boots? the lowest ones that go right on the tranny and the tcase shifters? both mine are cracked and are letting some water get into the fluid. thanks in advance
Unsafe at any speed
Offline mrfuelish
  • 2862
Re: while the engines out...
« Reply #1 on: February 27, 2006, 11:02:07 PM »
call trail tough,they sell a better than stock rear main seal, it's not cheap but should last a long time, check your clutch and bearings if you have one, change your timing belt and cam seals, water pump also.
Offline 92Sidekick4x4
  • 1456
« Reply #2 on: February 28, 2006, 01:30:44 PM »
check the clutch on it, if its on its way out may was well do that as well.
