5'' Calmini lift
  • 11 Replies
  • 2999 Views
Offline cstello
  • 33
5'' Calmini lift
« on: February 19, 2009, 12:53:23 PM »
I bought my 86 Samurai with the 5'' Calmini lift on it. It is really stiff. Is there any way to soften it up?
Re: 5'' Calmini lift
« Reply #1 on: February 19, 2009, 01:08:21 PM »
Is it the Spring Under lift or the Spring Over?
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #2 on: February 19, 2009, 01:14:09 PM »
Stare at a picture of Rosie O'donnell, maybe?
XL-7 front coils
1.5" rear coil spacers
Offline cstello
  • 33
« Reply #3 on: February 19, 2009, 02:26:01 PM »
Spring under
Offline Lindenmooch
  • 560
« Reply #4 on: February 19, 2009, 02:47:27 PM »
 :laugh:
  • 6603
  • 69
« Reply #5 on: February 19, 2009, 02:50:45 PM »
Different shocks.
Offline cstello
  • 33
« Reply #6 on: February 19, 2009, 04:44:43 PM »
Can anyone recommend a shock that would help?
Offline Zuken
  • 19
« Reply #7 on: February 19, 2009, 09:17:13 PM »
I have a 88 Sammy with stock springs, 6 " SPOA, 2" longer shackles and it is stiff.  I just put on extended shock mounts from RRO and I bought their extended shocks which are softer and the ride is better.  Remember the Sammy is light.  Putting on heavy truck shocks will make it REALLY stiff.  Next thing to do to make it ride better is either CJ/RUF (tons of stuff on the forums about this)  or to go the YJ conversion (also lots of stuff about this on the forums)
Good Luck!
88 Samiurai, SPOA 6 inch lift, 3.5" Bonz Shackles, Rear EZ lockers, 4.16 gears, Calmini OTS steering, 31" Truxus tires, Tri Mil header, Cherry Bomb, 2 " exhaust, RRO Front Bumper, extended shocks and shock mounts, Rock Biters, TT skid plate
« Reply #8 on: February 19, 2009, 10:12:02 PM »
Add weight to the front (bumper, winch...), or start wheeling the crap out of it. The springs will soften up. Samurai's will never have a "soft" ride... so... what you're experiencing could be normal.
« Reply #9 on: February 20, 2009, 09:48:21 AM »
Like Eric said, you need softer shocks.  The Calmini Spring Under lift will never be a soft ride like YJ springs though.  But it does mean you can rally around a bit faster.  :D
You might be able to get the numbers off of the current shock then find one with a lighter rating.  Not really sure as I run a SPOA and F-250 light duty shocks on my SJ.
Offline jdhiggs
  • 12
« Reply #10 on: February 24, 2009, 09:15:46 PM »
i have a 4" sprung under bds suspension lift i bought it used for 250 bux installed it last sat and it has bds' shox seems to ride typical of a sammi thats lifted  i thank there shox are a  lil pricey though
Offline Dimitros
  • 75
« Reply #11 on: February 24, 2009, 10:39:25 PM »
Samuai is a "hard one" car itself, by design. I got Calmini 3.5", and it seemed to me much softer then was in stock. "Hard" means better cornering and safety on-road for such a little truck.
Just don't understand why are poeple on all Zuki's forums from time to time asking questions about Sammi's stiffness.
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
