Worst case scenario
  • 1856 Views
Offline brace
  • 264
  • I built it; I break it; I fix it.
Worst case scenario
« on: May 04, 2004, 01:32:21 AM »
I can buy an 87 hardtop for $250.  It won't go into gear.
It has 59k original miles and it starts up and runs just fine and there's no rust on it.  The transfer case isn't locked up either.  I just want to know some of the probable reasons and cures.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
  • 6587
Re: Worst case scenario
« Reply #1 on: May 04, 2004, 01:54:23 AM »
Does the shifter wobble so bad it actually spins in a semi-circle? If so, the shift pin in the tower could be so worn out that it won't go into gear. To verify, hold the shifter so that it doesn't rotate and try to shift.
Good Luck, -Eric
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #2 on: May 04, 2004, 01:55:14 AM »
Don't know much about Sammys but it sounds like an awesome deal to me, I'd nab it!
Offline brace
  • 264
« Reply #3 on: May 04, 2004, 02:01:06 AM »
I'm going on second hand info about the tranny.  I will let you know if it is the pin.  I do plan on doing the nabbing tonight.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: May 04, 2004, 02:44:20 AM »
You can get a hell of a lot more than that out of it, just selling it for spare parts!  Only 59K miles???
It's not even broken in yet!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline brace
  • 264
« Reply #5 on: May 04, 2004, 03:31:07 AM »
I concure.  But it is a long way from being as prestigous as a SJ410.
