I don't get it??
  • 19 Replies
  • 3195 Views
Offline museboy07
  • 641
Re: I don't get it??
« Reply #15 on: June 18, 2007, 07:06:26 PM »
so your tellin me i could shift at 5 grand and shouldn't even have problems? I mean thats not even red line...I never take mine past 4 grand
Offline PHX96TRACK
  • 90
« Reply #16 on: June 18, 2007, 10:43:01 PM »
Yeah you should be able to rev it up to 5,000+ unless your engine is going to go soon anyway. The redline means the engine was designed to rev that high. I don't take it that far,  ( to the limiter ) but I'll go to 5-5.5 if needed.
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #17 on: June 19, 2007, 05:10:45 AM »
Larger tires change the load on your engine so that the engine cannot provide the torque needed to move the truck at various speeds.  You need to change the gearing on your drivetrain to get the engine power band and driveline loading back to normal.
I put 30 inch BFG-AT/KOs on my 1.6 8-valve Samurai with a stock drivetrain.  While the engine was an improvement over the 1.3, I still had power problems in daily driving.  This last weekend, I swapped my 3.73 Ring and Pinions for 4.62 units and the drivability difference was amazing!  No bogging down at highway speeds in 4th or 5th gear.  I could let the clutch out at idle while stopped on level ground and the engine did not die or struggle.
Redlining the engine will eventually result in a blown engine - which is a lot more expensive than re-gearing your differentials...
my 2 cents...
Ack
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #18 on: June 19, 2007, 05:08:04 PM »
I run mine down the highway and it's running 42-4300 rpm's.  When I need power, I always need to shift around 5 grand
96 Tracker
32 MTR's Warn 8000i
Offline slade11_98
  • 22
  • 97 Geo Tracker with performance 1.6 16 valve.
« Reply #19 on: June 19, 2007, 08:39:46 PM »
Ive been there and done that. I was running 31 mud kings on my 95 Geo 5 speed. The best combo is to run the Hawk torquer cam and header. 5th gear will come back to ya!
