INNER SPINDLE BUSHING
  • 1 Replies
  • 1214 Views
Offline Alvis
« on: July 27, 2019, 03:49:16 PM »
Hi All!
So I have a 1995 tracker and I have heard that you can get a bearing upgrade for the inner spindle bushing, P/N 43445-60A10???
Thanks.
2002 Tracker ZX-2, 2 door removable tops 2L, two inch lift, 235/75/15 Duratracs, K&N air filter Bull Bar
1995 Tracker 1.6 16V. 2 door removable tops bias ply Super Swampers.off road only.
2002 Vitara two door removable tops, parts car
1995 Tracker two door removable tops, parts car
1992 Tracker two door removable tops, parts car
Re: INNER SPINDLE BUSHING
« Reply #1 on: July 27, 2019, 06:42:28 PM »
I can't speak specifically about the trackers, but, later Suzuki models did have a bearing rather than a bushing - the bearing part number is 09263-28030, the parts manual shows it  as 28x35x16, however, I cannot guarantee that you can remove the bush and replace it with the bearing, you may need to replace the spindle as well.
