ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: hobgoblin on January 25, 2006, 04:13:42 PM
Title: Hagan widening set-up??Need left side axle stubs
Post by: hobgoblin on January 25, 2006, 04:13:42 PM
Hey All,
Thinking about tring this out,I understand most of it,But can you use a 1/2 spacer on the passenger side axle.It's not going to be easy to find 3 left side drive axle stubs.Any body got one that they would sell??
Thanks Tom K.
Title: Re: Hagan widening set-up??Need left side axle stubs
Post by: brlj on January 25, 2006, 04:23:30 PM
Are you going to run the Toy cv's? If so you only need 1 extra plus its a lot stronger setup. I got tired of busting stock cv's and front spider gears so I went with the Toy cv's and Sammy diff upgrade. Itll save you money and hassle in the long run.
Bill
Post by: hobgoblin on January 25, 2006, 04:36:57 PM
Ok Guys,
What Toyota  axles?? Year  make  and model PLEASE!!Only thing   I  can think is |removethispart|@95  truck???I'm  sure  they  are stronger.Will they  bolt  to the stock axle  stubs??
Thanks  Tom K.
Post by: Uncivilized on January 25, 2006, 06:20:37 PM
What if your not changing the cv's - then could you use spacers? Or would longer bolts to accomidate for the spacers be a weak link?
Post by: 37kicker on January 26, 2006, 05:36:42 PM
what Bill is talking about is a toy axle conversion kit i have avalible.  you use ifs toy axles instead of kick ones .   stan
