ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: ed oorklep on March 03, 2005, 10:13:30 PM
So I'm putting new brake shoes in my rear drums. But the spring's in there are a real pain in the *ss to get back in. Please tell me there is a way to make it easier because I really can't get 'm back in >:( >:(
I assemble the springs on the shoes first. Then I locate one shoe and pull the other one into place
Why not do disk brakes and forget about all the springs? ;D I'll have mine done this weekend. 8)
Use a brake spring multi tool.
~Nate
(or a screw driver and various pliers.)
brake sping tools r like $25 at the parts store it will make ur life a lot easier. make sure the ones u get have instructions. because a screw driver can be used in the same fasion.
I just use my vise grips to grab onto those little critters!
the needle nose vise grips are the best, they don't slip off the spring & you can twist enough to get into the various holes
It's in the planning stage now ;D
But I finally got them on today thanks for all the input, it helped ;D
There's gonna be drum brakes to work on for quite awhile for me on one thing or another & the brake spring tools make disassembly & reassembly quite a bit easier. Good to have around. Glad you got 'r done without, though!
I use side cutters. make sure the adjuster is fully deadjusted first
