ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: jzap on March 03, 2005, 03:47:28 AM
i have a 96 tracker. Lately I have to really stomp on the clutch to get it to let the starter engage.  Where is the starter lockout switch located, and is there an adjustment that I can make, or can you just put a jumper across it without burning something up?
Give it a check for dust bunnies.... sounds simple enough. Mine actually quit working because of how dirty is was. There is a way to test it, it specifies how to in the hayes manual.
Mine does the same, and I'm planning on rerouting the wires and using them for a kill switch up under the dash somewhere. I had a look under there and I'm lacking the double rear-articulated elbow to try and adjust the blasted thing. Just my .02 ::)
SPLICE THE WIRES TOGETHER AND BYPASS THE SWITCH.
IN COMES IN HANDY TO RESTART IN GEAR IN LOW RANGE. I JUST DON'T LET ANYONE ELSE DRIVE IT FOR SAFETY SAKE
ROSS
I finally took the time to crawl underneath the dash.
Turned out to be reeeeal simple. The switch is mounted on a threaded stem. Disconnect wires, loosen jam nut (14mm) twist the switch a turn or so, tighten jam nut, plug it in...
