ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: keith on February 03, 2006, 07:41:20 PM
Title: What gasket do I need between the manifold and cat converter?
Post by: keith on February 03, 2006, 07:41:20 PM
What type of gasket goes between the exhaust manifold and the catalytic converter?  At Autozone they said a donought type on went in there.  I don't think that is correct because the downpipe is two pipes at the top that go into one.  Also I seem to see remnants of a flat gasket on the truck.  I have an exhaust leak in that area and can see that the gasket is broken.  Also I was missing 1 bolt and another was very loose.  Is there anything special about those bolts or can I get them at a hardware store?  Thanks.
Title: Re: What gasket do I need between the manifold and cat converter?
Post by: da_tub on February 03, 2006, 09:59:28 PM
nope don't think there's anything special abouthem, and i belive your right about the flat gasket part..
Post by: biker on February 03, 2006, 10:10:04 PM
yes you need a twin pipe gasket, if I remember correctly it also fits VW's also
Post by: karl214 on February 04, 2006, 02:53:18 AM
Autozone calls them a packing gasket...  ;D
Post by: wildgoody on February 04, 2006, 08:19:20 AM
Get Stainless bolts and nuts,
this way you will get them off
again, regular hardware will
corrode on perminent
Post by: keith on February 04, 2006, 10:52:50 AM
Advance Auto had the gasket I needed.  It was $2.00!  Now I'm back on the road.  Advance Auto had a much better setup for finding parts than AutoZone did, plus the had the gasket in stock.
