ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: djp4 on March 02, 2005, 03:14:41 PM
Title: Coilover???
Post by: djp4 on March 02, 2005, 03:14:41 PM
What is the definition of coilover suspension lift?
I'm new at this as you can guess.this guy says he has a coil ove rlift kit in his tracker ! :-/
Title: Re: Coilover???
Post by: Natebert on March 03, 2005, 02:35:32 AM
I'd say that his original suspension was 'coil-over' to begin with.  Coil over axle, at least in the rear.
But he might have modified the front to SAS (solid axle suspension) from IFS (independent front suspension) and used coils on top of that axle too (like the rear end) and is calling it that coil over.
my 2 bits.
~Nate
Post by: 1bigtracker on March 03, 2005, 03:22:39 AM
Isn't a coilover a type of shock that has the sping wraped around the out side of the shock?  that what i always though.  And there is some one builing coil over suspension for the tracker.  I think they are called "Shogun"?
stu
Post by: Natebert on March 03, 2005, 04:01:41 AM
They have coil over shocks too!
(would be wierd to see a coil under suspension)
Post by: tracker8wr on March 03, 2005, 07:36:42 AM
stu
u r correct coilover refers to the coil being over or around the shock or stut. higher end luxury cars come with coilover struts, like lexus. there was a guy on here talking anout he had developed a lift with a coilover strut.
Post by: 3wheelerdude on March 03, 2005, 08:18:38 AM
stu
Isnt a spring coiled around a shock called a MacPherson strut??? I thought the coilover was simply the spring coil.
Post by: ed oorklep on March 03, 2005, 08:25:57 AM
Nope, what we have on our trackkickvit's in the front is a MacPherson strut it's just a shock for IFS and a coil over is a shock and coil in one.
Post by: explosivo on March 03, 2005, 08:51:15 AM
well, the only difference between a shock and a strut is that the strut is mounted solid on one end instead of pivoting (2+ mounting bolts rather than one)
Post by: djp4 on March 03, 2005, 12:17:33 PM
Thanks for all the info.Your all right thats exactly what it is. ;D ;D
Post by: Rhinoman on March 03, 2005, 10:54:42 PM
I hope he has reinforced the strut tower  :o
Post by: tracker8wr on March 04, 2005, 08:16:58 AM
with a coilover stut lift/conversion u would have to reinforce the tower it is not made to support a load just to keep thing stable. i bent mine last weekend and need to straighten it back and build and sturt tower brace but i was beating on it pretty hard.
