ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Agent Orange on February 08, 2006, 10:43:11 AM
Title: 26-Spline vs. 22-Spline pass. CV
Post by: Agent Orange on February 08, 2006, 10:43:11 AM
OK last weekend I swapped out my aluminum housing & 3rd for a steel GV unit with a 26 spline carrier from a sport. during installation, instead of just changing the passenger CV right out I just changed the 26 spline cup that goes into the axle housing with one from a X-90. Everything seemed to swap straight over no problem. The next day the guy from the shop were I did the work, said he couldn't put the 22 spline cup onto the X-90 CV saying it was too small. He didn't try hard enough to make it fit, he just called me the other day saying he thinks we made a booboo with that swap.
Anybody know if there is a difference in size ?
Title: Re: 26-Spline vs. 22-Spline pass. CV
Post by: 37kicker on February 08, 2006, 10:55:58 PM
the 22 spilne will fit in but will not engage the spline  :'(
Post by: Gear on February 09, 2006, 12:36:44 AM
are you using a GV center or a vit center?  A Vit/x-90 26 spline stub axle will go into a GV center, but will stick out more as the shaft/spine is longer than a GV stub axle.
Jeff
Post by: pdasilva on February 09, 2006, 05:32:35 AM
I had a problem swaping a 22 spline cup to 26 pline cup,i just had the the inside of the 26 spline machined.I think the diffrence was about 0.5mm between the two inside diameters.
Post by: Bobzooki on February 09, 2006, 01:17:19 PM
I just threw it all away and put 4Runner axles in...   ;D
Post by: Agent Orange on February 09, 2006, 06:16:41 PM
0.5mm huh i wonder why, anyway i'll just swap in the one from the x-90 when i do my 4dr brake upgrade.
is that toy axles front, and rear ?
thanks for the help everyone  ;)
Post by: binkie on February 09, 2006, 07:46:32 PM
How easy is the 4-runner axle swap?
Thanks,
Marc
