ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: truckasaurus44 on February 10, 2006, 08:32:22 AM
Title: LATE MODEL TRACKER GEAR QUESTIONS
Post by: truckasaurus44 on February 10, 2006, 08:32:22 AM
I've got a couple questions.
1) Are the front and rear 3rd members from the earlier Tracker/Sidekicks interchangable with later model tracker/vitaras, specificly the 2.0L 4cylinder models?  I'm guessing I'd at the least need to use a 26spline front diff fron the later trackicks.
2) In which year did the kick front go from 22spline to 26spline?
3) Also, does anyone know the stock gearing on a  2000 chevy tracker 2door 4cyliner 5spd 4x4?
Title: Re: LATE MODEL TRACKER GEAR QUESTIONS
Post by: the_maplebar on February 10, 2006, 08:41:36 AM
Yes.  http://www.zukiworld.com/month_030104/feature_tsb_shiftontheflyremoval.htm
4.625
Post by: bzzr2 on February 10, 2006, 10:58:15 AM
my 2.0L 4 banger has 5.12's, but it's an 03.... ZR2  get your VIN # and call GM's service hot line and they "should" be able to tell you exactly what's in your vehicle.
Post by: truckasaurus44 on February 10, 2006, 02:18:12 PM
OK, so I'll need a Japanese built tracker to snag parts from....thats fine.  only one question, how many of the trackers that I see driving around in New Jersey and the surrounding area are made in Japan.  Is this going to be a fairly easy or nearly impossible hunt?  Also, if I'm reading this right I'm going to need more than just the diff for the front, mainly the diff, inner axle, and passenger CV.  Is that it?
Post by: truckasaurus44 on February 10, 2006, 08:07:07 PM
On e-bay all i could find are canadian built trackers (vin numbers that don't start with a js)
Post by: Sidetracker on February 10, 2006, 09:15:19 PM
If the vin number starts with a 2 it was made in Canada
Post by: truckasaurus44 on February 11, 2006, 07:25:14 AM
um, ok...still means every one I see on e-bay is a canadian.  Why can't you use a 1997-98 canadian tracker?  What did the Japanese do different?
Post by: truckasaurus44 on February 12, 2006, 06:37:49 AM
Come on, Someone's got to know the difference between the Japanese built and Canadian built tracker's front end
Post by: the_maplebar on February 13, 2006, 09:53:33 AM
I'm not sure what the difference is, but if you look at a parts catalog they do list some of the front end parts as being different.
Post by: truckasaurus44 on February 13, 2006, 09:56:00 AM
I'm just wondering if its something minor that I could work around
Post by: tOnKa TrAcKeR on February 13, 2006, 11:27:16 AM
The only japanese built trackers i have ever seen are 1989 and a very few early 1990
everything after 1991 were canadian built
Post by: Bobzooki on February 13, 2006, 02:06:03 PM
Sidekicks through 1995 are 22 spline.
1996 and newer are 26 spline.
Were the X-90's all made in Japan?
I know my wife's 1999 GV is Japanese, but both of my 1995 Sidekicks (2-door and 4-door) were made at CAMI (Ontario, Canada)
Post by: offlimits4wd on February 13, 2006, 05:42:06 PM
im not sure what differences they have because i just cut the suspensions off and straight axle them but i have tons of tracker parts and i just took the complete suspension of a 2002 grand vitara limted v6 i want to get rid of
Post by: truckasaurus44 on February 14, 2006, 09:37:10 AM
Maybe the article is only refering to the need for the 26 spline setup.  I was under the impression that the diff housings were dimensionally the same  for all Track-kicks and Track-vits, so I should be able to swap the entire center section and passenger cv shaft from any 26 spline track-kick into my 2000 tracker.  Whats the worst thing that could be mismatched, the drive shaft bolt pattern?
Post by: the_maplebar on February 14, 2006, 10:24:34 AM
I've been looking at this online catalog:
http://www.suzukicarparts.com
It looks like the diff housing is the same between the Japan and Canada built Sidekicks.  The Passenger side CV axle assembly is slightly different, but I'm not sure what.
Post by: truckasaurus44 on February 14, 2006, 07:51:18 PM
Yeah, I'm guessing the key is the cv shaft, maybe the length.  Someone on another site said that the only Japanese kicks he'd seen were the Sidekick sports, but the article says a 1.8L sidekick wouldn't work which means that isn't the answer
