ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mikelx on March 19, 2006, 10:20:16 AM
Title: How many body mounts???
Post by: mikelx on March 19, 2006, 10:20:16 AM
Hey everyone "newbie" here, I just recently picked up a 91 Tracker 4X4, and I'm sure this question has been asked before......how many body mounts are there on a 91 tracker and where are they located (ie. 2 on either side of the frame or on the bumpers???) Just trying to do a cheap body lift on her..Also what could I use to lift it without spending a lot og cash ???..Thanks Mike
I will try to get some pic of the tracker soon.....
Title: Re: How many body mounts???
Post by: wildgoody on March 19, 2006, 10:25:21 AM
8, the rear and the ones under the body are all
the same, the fronts are different, there is a capture
nut in the frame, and long bolts to hold it all together
Post by: mikelx on March 19, 2006, 10:59:11 AM
Do you have to remove the bumpers to get at the front and rear mounts?? Any suggestion on what to use to lift it i've heard pucks?????
Post by: wildgoody on March 19, 2006, 11:02:28 AM
I would say get the lift kit, it's like $120
and has all the parts needed, unless you
want to fabricate all your own stuff, it's a
little more involved than just throwing a
couple of pucks under there and calling it
done, tho that could be done, I wouldn't
do it that way, you will have other problems
it you do a half baked lift kit
Post by: Uncivilized on March 19, 2006, 03:44:52 PM
You can't use hockey pucks, not only are they not good material, the body bolts are welded to the body, and they're not long enough. You will need to buy a kit, or some people use 3x3 box steel. You need 12 blocks, 8 mounts, plus there are 4 non-bolted supports you need to address.
Post by: BigPig on March 19, 2006, 05:25:31 PM
Go with Sky's 2" body lift ($120) and coil spacers ($80 for 4).  For $200 and a few hours time you will be able to fit 31" tires. :D  http://www.sky-manufacturing.com/
Or you can search for posts about home made body lifts like mine and use the coil spacers.  I'm very happy with my home made body lift, but I'm on a serious budget (family of 5 on one income).  If I had the money I'd have gone with Sky's body lift.  Check out my pic below for how mine looks with the coil spacers and my body lift.  I can shoot you some pics if you want to know how I did my body lift.
Post by: hobgoblin on March 19, 2006, 07:03:43 PM
Go with Sky's 2" body lift ($120) and coil spacers ($80 for 4).  For $200 and a few hours time you will be able to fit 31" tires. :D  [url]http://www.sky-manufacturing.com/[/url]
That's what I got...I took the rear bumper cover off,And the headlights out.You wouldn't have to remove the front bumper..I made a custom baja/winch for the front.Back is still Missing...Sky's is the most cost effective way to lift a Tracker... ;D
Post by: mikelx on March 20, 2006, 05:12:29 PM
Please send me pic's of what you did to mikelx8|removethispart|@aol.com...............Thanks Mike
Post by: hcgalvin on March 21, 2006, 12:41:49 PM
See my budget lift article at:
http://www.zuwharrie.com/content/view/11/27/
or
http://www.granitepath.com/~irving/suzuki/budgetbodylift/index.htm
If you have a 2 door, not a 4 door, you can still follow the same principles.
Heather
Post by: mikelx on March 21, 2006, 10:43:07 PM
Thanks Heather.............I just may try that this weekend....Mike
