ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: rfields on March 24, 2006, 08:52:47 PM
Title: 2.5 gm quad four swap
Post by: rfields on March 24, 2006, 08:52:47 PM
has any one ever tried to put a 2.5 quad four in a sami
Title: Re: 2.5 gm quad four swap
Post by: kymike on March 24, 2006, 08:54:53 PM
its mike
Post by: tOnKa TrAcKeR on March 25, 2006, 11:07:44 AM
umm the gm Quad4 was a 2.3L untill it was replaced in 1996 with the 2.4l "Twin Cam" motor.  But why would you want to put a FWD motor in a sami ? Especially one as unreliable as the quad4?
Post by: Jookycola on March 25, 2006, 02:42:26 PM
As a long time member of j-body.org and owner of 2 LD9 powered (2.4L) Z24's.  i will second the question rfields asked.  Why would you put that peice of junk motor in a sammy?  do the 2.0L swap from trail tough....trust me it doesn't take much to get those sammies flying.
Post by: bandit86 on March 25, 2006, 05:40:06 PM
the 2.5 quad 4 was also in s10s as a rear drive engine.... maybe not called quad, bnut the exact same engine
come to think of it,  maybe it was the 4 tech engine.  I know my citation and celebrity had the same engine as the s10s
No wait, it was the iron duke 2.5
Post by: urbanwheeler on March 25, 2006, 06:33:41 PM
if you are going to do a swap, dont use a gm motor(especially their 4 cylinders). If you want a challenging swap that they dont make a kit for, put the xl-7s 2.5 or 2.7 liter v6 in your samurai, or if you want to do it the easy way, get a 1.6 8 valve motor and an adapter plate, and put that in you samurai. I have heard great things about the 1.6 8 valve swap, and I have had people wanting to buy my tracker to swap the motor into their samurai.
Post by: JasonPugh on March 25, 2006, 08:46:56 PM
Yep, it will fit, but it is tight.  I have one half swapped in, but I'm abandoning the Idea for something lighter.  The power is only fair, but tha t motor is heavy.  If some one wants I'll make you a good deal on a 2.5 w/ a T-5 2wd transmission, stock harness and computer.
These motors are the tech4, also known as the Iron Duke.  Decent motors, just I want to go a different direction.
Post by: rfields on March 25, 2006, 09:04:31 PM
sorry it is a tech four and the only reason i even thought of it was because i have a spare one just sitting around
its in an 88 grand am. and the sammi i just bought to play with is smokin pretty bad(2qts of oil in one week)
i thought if it wasn't to complicated i'd just throw that 2.5 tech4 in for a while
Post by: bandit86 on March 26, 2006, 05:39:17 AM
nah, sell it for a replacement 1.6
