ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: kneescraper on April 18, 2006, 05:23:25 AM
I have a 95 2door and just got a 97 4door that has a dead motor. I got the 4 door because I need a front knuckle. Should I change all of the suspension? Will the 4 door stuff give me any lift, or better brakes?
What do you guys think of changing the complete wiring harness and computer to upgrade to the OBDII stuff? I know that would be a lot of work, but would it be worth it?
4 door brakes will be a good improvement on a 2 door. Suspension wont give you much lift but, if you want to do it, go ahead if you have the springs and what-not already ;)
Cant help you with the OBDII question. Im stuck with OBDI , havent had the pleasure of using the other..
