ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: rednecksammy on April 26, 2006, 02:02:27 AM
Title: run rich need help
Post by: rednecksammy on April 26, 2006, 02:02:27 AM
need to no y 94 geo 16 tbi runs very rich and on accel backfire thro intake?
Title: Re: run rich need help
Post by: FNG on April 26, 2006, 05:36:17 AM
Timing?pcm? :-\
Post by: wildgoody on April 26, 2006, 07:17:11 AM
cam timing, bad O2, dirty air filter, tune up ..........
Post by: derekj on April 26, 2006, 08:18:06 AM
cam timing - but also check the coolant temp sensor. if it is out of range the engine can run very rich.  how does the vehicle run? how fast can you get it going?
derek
Post by: Evolvocane on April 26, 2006, 02:13:32 PM
derek
I had that probem,   youcan checkthe sensor by placing it in hot then cold and checking the resistance values with an ohm meter.  makesure its the right sensor though,  there are two.  One for the computer and one for the gauge.
Post by: Carnage on April 26, 2006, 02:43:51 PM
MAF throwing a code?
(my situation)
(http://memimage.cardomain.net/member_images/1/web/673000-673999/673055_149.jpg)
X32...................X32CarDomainPage...................X32 (http://www.cardomain.com/ride/673055)
...................RyouBakua|removethispart|@Hotmail.com..................
Help me Heal!!!!!! CLICK HERE!!!!!!!!!!! (http://www.mgcluster.net/mguk_world1/?ac=vid&vid=11027759)[/color]
Post by: rednecksammy on April 27, 2006, 04:23:34 AM
what do you mean cam timming? do you mean the belt jumped a tooth? changed the tpc and iac didnt check temp senser yet but had to turn up idle becuse it runs ruff at under 1500 rpm swoped map from parts truck didnt make diffrents will check temp senser and get back to you all
 thanks ;D
Post by: wildgoody on April 27, 2006, 08:17:36 AM
yes, a slipped tooth would
also change ignition timing
