ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: ddevil on May 27, 2006, 11:47:57 AM
Title: body lift=bad???
Post by: ddevil on May 27, 2006, 11:47:57 AM
ok i was talking to a friend of mine and he was swearing up and down that if i put a body lift on my tracker that i was going to end up having problems because they're hard on vehicles.  now i've never heard of anyone having any kind of problems with a simple body lift.  suspension lifts yeah due to adding stress to the driveline, cv and such but a body lift?  this guy swears up and down though.  so it kinda had me thinking and worrying a little i guess.  so before i lift my tracker 2" is there any reasons i shouldn't?  someone please ease my mind so i can get some lift on my beast..... :D
mike
Title: Re: body lift=bad???
Post by: Yoak on May 27, 2006, 11:57:56 AM
Ive heard this before,
it has to done with the stresse put on the bolt's that hold the cab to the frame.
However most people on this board are running them and have no issues...
now if you got with something extreme on the other hand...well thats different
Post by: Jeremiah on May 27, 2006, 11:59:22 AM
2-3" are fine. Use good bolts.
~J~
Post by: lowrezolution on May 27, 2006, 12:08:13 PM
Stick to 3" or less. A body lift done correctly is one of the best and cheapest way to gain tire clearence. We are so limited to suspension lift that this is one of the only options without spending mega bucks and sacrificing streetability.
Post by: ddevil on May 27, 2006, 12:20:30 PM
cool, yup i'm using grade 8 bolts.  thanks guys....
mike
Post by: Shredder on May 27, 2006, 03:50:17 PM
 ??? What kind of a 2" body-lift are you putting on that Tracker? Most of the 2" kits use a custom metric "female bolt" that threads onto the stock studs that hang out of the body.
Post by: Quaddawg on May 27, 2006, 04:08:10 PM
Actually, most are those crappy box tube lifts, I only know of one or two of the female bolt types..
me, I disagree, I think body lifts are an absolute last resort and rather........well...... let's just say that on trackicks, I see why folks do them, but I don't have to like it.. lol..
Post by: Uncivilized on May 27, 2006, 06:08:02 PM
Actually, all 2" body lift for the tracker use female sleave nuts and plastic like blocks. The only "crappy box tube" ones are either Calmini 3", Masterkit1 3" or custom built 3".
Post by: Quaddawg on May 27, 2006, 07:27:30 PM
oh, then my mistake.   sorry.
Post by: ddevil on May 27, 2006, 07:53:18 PM
well i was going to put on some "crappy" square tube blocks but much to my dismay after i got everything apart and the driver side jacked up i realised that it wasn't going to work without cutting the stock body bolts and i don't want to do that.  so now i'm going to just suck it up and buy a 2" lift from sky offroad design.  thanks though everyone for the help.
mike
Post by: Uncivilized on May 27, 2006, 08:20:13 PM
mike
You don't need to cut the stock body bolts if you do 3" box tube.
Post by: ddevil on May 27, 2006, 08:42:25 PM
yeah but if i go 3" then i'll have to extend the shifters and the steering and i don't have a welder or anyone that could do it for me  :'(
Post by: Yoak on May 27, 2006, 08:51:45 PM
Go with 2" then, seems to be alot easier  ::)
Post by: trackenator on May 27, 2006, 09:21:46 PM
I put a 3in bl on my 92 tracker(along with 2in jeep spacers)no welding on the steering didnt (but should) extend shifters ,just a little cutting. used original body bolts "made" my body lift using big washers,jacked up vehichle slid on washers(total of 12,on each bolt,i think) welded(at muffler shop)metric nuts on(4in) metal tube that just fit inside of the washers and extended thru the frame then bolted to the frame.much easier than jacking up high enough to fit 3in block,the washers you can slide in as soon as the bolt clears the frame. been running it for 2 years now with no problems cheap and effective. didnt need to do anything to the filler neck of gas tank either. I run 31x 10.50 swampers and have no problems except rubbing on frame at full turn no fancy backspacing or anything either used 15 x 7 rims have enough room for34 x 10.50 as soon as funds are available.
Post by: ddevil on May 27, 2006, 09:42:12 PM
hmmm..... now that's not a bad idea...  what size of washers did you use?  i imagine probably around 2" o.d.  and where exactly did you place the washers for the front blocks?  i don't know why but they confuse the hell out of me :\   thanks....
yoak- lol, yeah i know...  ALOT easier right lol
Post by: Maroon Monsoon on May 27, 2006, 09:56:44 PM
I totally agree with quaddawg. I believe body lifts should be a last resort only. I'd get some suspension lift on that thing and see where you're at before body lifting.. unless you already have suspension lift. If the body is in bad shape just hack away instead of body lift after you suspension lift and get bigger tires
Post by: ddevil on May 27, 2006, 11:52:57 PM
well i agree but it's like this,  i really can't afford too much for a little while but i'd really like to get some cheap lift so i can at least afford some bigger tires so i can do a little more aggressive off roading.  then the suspension lift will come but probably not till the end of summer.  can ya dig it?  oh and the body is in great shape along with the rest of it so i'm really trying to shy away from cutting anything.
mike
Post by: Quaddawg on May 28, 2006, 04:37:12 AM
Stacking up washers?????
You have GOT to be kidding me.
Post by: lowrezolution on May 28, 2006, 05:55:55 AM
If your looking for cheap, try the "garage sale" at boondox, they have some 2" bds body lifts on close-out for cheap! :)
http://www.boondoxmotorsports.com/garagesale.html
Post by: ddevil on May 28, 2006, 06:06:35 AM
what could possibly go wrong..... :o
<rhetorical question filled with sarcasm>
Post by: Quaddawg on May 28, 2006, 07:58:16 AM
LOL.... oh... nothing I guess.. I am sure that is the correct method    :P :-X 8) ::)
Post by: Rhinoman on May 28, 2006, 08:23:28 AM
I have to disagree, a good suspension lift should have more travel, therefore the suspension should come up just as far as the stock suspension. True it will require more force to compress the suspension fully but it still doesn't leave any extra room for more rubber. If you want bigger tyres then you either have to body lift or cut, I'm not a fan of either but its a means to an end.
Post by: ddevil on May 28, 2006, 09:18:19 AM
see in my eyes i figure like this... the only way to get 'everything on the vehicle' off the ground is to put bigger tires on.  see if you do a suspension lift with the same size tires, sure you get some lift but you still have the axles sitting where they already were.  so the cheapest way to go would to be to do a body lift and bigger tires then the suspension.   make sense?
oh and you'll be happy to know that i'm working on getting roger brown at 4crawler offroad custom body lift kits, some information so he can start developing body kits for our trackicks.  yeah i know there's already kits out there but i figure maybe he'd be a little cheaper and he uses top quality parts.  so no washers or hockey pucks or shopping cart wheels for me :P
mike
Post by: Quaddawg on May 28, 2006, 01:54:23 PM
Nah, cutting em up is cheaper than body lifts.. and leaves your center of gravity closer to the ground.
Post by: Uncivilized on May 28, 2006, 07:26:24 PM
You still may need to extend the shifters with a 2" body lift as well, the shifters are easy to take out, you could take them to a welding shop and get them extended pretty cheap. I don't have anything against 2" body lifts - just don't choose it because you think it's easier, most things needed to be done are the same, just an extra inch.
BTW - shop around for a 2" kit, some kit's don't include bumper lift brackets, so if you're running stock bumpers, BDS suspension has the most complete 2" body lift kit(bumper brackets, steering shaft extension, 2" t-case shifter extension, fuel filler extension, full instructions)
Post by: Maroon Monsoon on May 28, 2006, 11:36:30 PM
lots of lift kits come with bigger bump stops. It is because unless you relocate your shock mounts, once you put bigger ones on the axle can't go up as high and the bigger bump stop is so the shock doesn't quite max itself out upwards and mess itself up. You still get more up travel because it's sitting higher and you get allot more downward travel. So basicly unless you redo the shock mounts the axle will not go as close to the body as it would when stock. I see the point in body lifting if you don't want to hack a nice body but your argument kind of lacks a bit in the up travel aspect of it because it usually can't go up as high as stock. I still say it's a better idea to hack the body than body lift it, you get the space required because unless you barely upped your tire size the bigger shock and bumpstop won't give you that much extra room. as quaddog is pointing out, lower center of gravity with hacking VS body lift.
Post by: Rhinoman on May 29, 2006, 07:25:47 AM
[lots of lift kits come with bigger bump stops. It is because unless you relocate your shock mounts, once you put bigger ones on the axle can't go up as high and the bigger bump stop is so the shock doesn't quite max itself out upwards and mess itself up. You still get more up travel because it's sitting higher and you get allot more downward travel. So basicly unless you redo the shock mounts the axle will not go as close to the body as it would when stock. I see the point in body lifting if you don't want to hack a nice body but your argument kind of lacks a bit in the up travel aspect of it because it usually can't go up as high as stock. I still say it's a better idea to hack the body than body lift it, you get the space required because unless you barely upped your tire size the bigger shock and bumpstop won't give you that much extra room. as quaddog is pointing out, lower center of gravity with hacking VS body lift.
The original question was about a Tracker, the Tracker has unused travel in both front and rear struts/shocks. Struts choice is limited but you can lower the stock strut 2" without needing to extend the bumpstops, theres no point in going any further because of the CV angles. The front spring has an effective rate of 156.5lbs,  Stock front compression is 3.94", call it 4" to simplify the maths. If you make the spring 2" longer then you get 6" of compression travel so to fully compress the suspension it takes 6*156.5lbs, rather than 4*156.5lbs. It can still fully compress but it will do it less often.
The rear is similar, unless you fit a much longer shock you don't have to relocate the rear mount. If you do fit much longer shocks and relocate the top mount then you're back where you started, the same amount of uptravel as stock, but a longer spring to compress and hence more force needed.
You can extend the bump stops to keep the tyres out of the arches but then you lose suspension travel, which you don't with a body lift.
Post by: Maroon Monsoon on May 29, 2006, 11:38:17 PM
but then why does a calmini kit come with bigger bump stops for the back? I am 99% sure it does. I know what you are saying with the front but with the back I didn't know there was unused travel with the stock shock when fully flexed. I am pretty sure it's a good thing to have just a little so it barely doesn't max out the shock. So I'm seeing your point there but I still stand by cutting being a better option but I won't put a body lift agianst anyone with a perfect bodied rig that doesn't want to do too much hacking to it
Post by: Rhinoman on June 09, 2006, 12:47:44 PM
I'm not anti-cutting, I like the idea of keeping the truck as low as possible. I bought my Vit new and really didn't want to cut it.
I've been out and pulled my rear suspension and I have to put my hand up and admit to being wrong. I haven' t seen a kit for a Track/Kick with bumpstop extensions but you got me thinking and worrying a little.
My 3" Calmini kit has no bump stop extensions. I bought it used but I've looked at the pic on the Calmini site and at their description of whats included and theres no reference to any. Now I've taken some measurements and against the bumpstop there is around 13" of shock clearance and around 5" of spring clearance. Thats not good because the Calmini shocks are around 15" long compressed, looking back on this forum the stock shocks are 13" compressed so they have actually maxed out the travel. According to my calculations the Calmini spring fully compressed would be 6 1/2", I haven't got a stock spring handy to measure, Although I'm pretty sure that I've got one somewhere.
This means that I do need to extend the bumpstops, the shocks aren't an issue because the top mounts are being relocated anyway (longer shocks to go on) but the springs are going to sag if I leave the set up as it is. I'm going to repeat this exercise on the front suspension as well but I probably won't get to that for a couple of weeks. I'll post up what I find.
Its an important subject and I thank you for making me go back and investigate this. I wonder how other aftermarket suspension setups stack up. It certainly doesn't look good for those using spring spacers.
Edit: To be fair to Calmini I should have said that its possible that the rear spring could sag, given its length it would take a lot of weight to compress it that far.
The figures I gave above for the front strut lengths are correct as I have measured them previously
Post by: Maroon Monsoon on June 09, 2006, 03:38:19 PM
yea, I just put teh pro comp shocks from boondox on that are supposed to be 0-2 inch lift and they definatly bottom out.. I need to extend my bump stops and lift it to make them work right. They also unseat when fully flexed (articulates much better)sounds like calmini shorted you bump stop extenders. I am not sure about the springs sagging if there is excessive up travel but I don't think it would take more weight to make them go up 8 inches than 2 or something unless they are progressive rate coils. a friend of mine has a grand cherokee with lift coils and coil spacers and stock pads. it has soo much flex and I don't think his coils have really sagged at all yet. I do see how it could be really hard on the coils to do that though, just not sure if it really is or not
I am seeing the point of a body lift though even with new bump stops cause my new shocks do max out upwards and when it's fully flexed it doesn't lose that much upper wheel travel like that. It only has like 2.5 inches of up travel tops right now so I really need to lift it and extend my bump stops. but my sayng the bump stops would likely take care of the tire clearance in many cases was probably not correct cause once the axle is all angled the tire still goes up high and my shocks are stopping it
yea, that's probably worded like crap but oh well. best of luck to you with your future mods you mentioned
