ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Guardrail on February 10, 2005, 03:34:16 PM
I was thinking of getting some longer shocks for the rear of my gv. Drivetrain.com says my gv uses the same rear shocks as the trackick. So I am hoping somebody can tell me which is longest. Crown Vic shocks, OME shocks, or Calmini shocks. Any info very helpful.
Thankyou.
Bri.
How much longer do you want to go?
Procomp can supply shocks pretty much whatever length you want.
Same with Rancho and BDS.
I am planning on using the Calmini 2.5" lift in conjunction with perhaps a 2" spring spacer in the front and a 3" in the rear. I am also planning on lifting the body 2". I would like to be able to run 31"-32" tires and I don't want to move bump stops unless I can do it with a wrench because I can't weld. I plan on running many of the trails around Phoenix Az. I was looking for the longest travel shock without getting overly complicated with any kind of custom one off set up.
