ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: allian on May 31, 2006, 01:14:56 PM
i just changed the front driver side axle, pulled the axle pin. everything was alright i noticed there was a ring lying on the ground. i don't know where it came from. i tryed fitting back but there wasen't enough room for the ring and the pin? will it be okay with out that ring? cus really i don't know where its suppost to go.
Front axle?
Ring goes on the end of the axle shaft,
it's what keeps the axle from coming out,
so no, it will not be allright without it.
Front axle?
ya front axle. thing is i tryed puting it before the pin and theres no room??
Take a pic of the clip and the axle for us to see.
Inner section of CV axles on a Kick???
outter part that goes through the rotor
Front axle?
thanks again!
everything worked out, i just don't know what happend why it wouldnt fit earlyer?
thanks for all the info guys!
Sometimes the axle slips out a little and doesn't seat right, that was probably the problem.
that exactly what happend. sometimes you gotta force things to go rite. :P
