ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mozone on May 31, 2006, 06:58:27 PM
Title: need help with tsb- recalls
Post by: mozone on May 31, 2006, 06:58:27 PM
can someone direct me on where to fine the tsb/ recall info on a 2001 zr2 tracker? i have a rattle in the front timing chain area and rememberd the was a tsb or recall on this can anyone help? thank you, mozone.
Title: Re: need help with tsb- recalls
Post by: the_maplebar on May 31, 2006, 08:30:32 PM
You can search for a recalls, and a description of TSB's at NHTSA.
http://autopedia.com/html/NHTSA.html
Last I checked Chevy never issued a TSB for the timing chain, they issued a TSB for the valve lifter being excessively noisy because they are not adjusting properly.  I know  :(.  Unfortunately since it's a TSB and not a recall, it will cost you a nice chunk to have it taken care of.
Post by: mozone on June 01, 2006, 08:35:34 PM
thanks will check into it. think it could be the water pump that is the only other mild issue i have with this truck. t-stat out but it still reads half way on the gauge.
