ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: dwcrisp on February 05, 2005, 02:36:03 PM
Title: Tracker vs Sidekick grill
Post by: dwcrisp on February 05, 2005, 02:36:03 PM
I have a 98 Tracker 2dr softee.  I HATE THE GRILL!
Would a 98 Sidekick grill be a direct bolt on replacement?
My 98 bolts on with one center bolt and that is all.  I wonder if the Sidekick is the same?
anyone tried it?
Title: Re: Tracker vs Sidekick grill
Post by: HotRod on February 05, 2005, 02:49:00 PM
Should be a streight swap.
I could be wrong.
Post by: wildgoody on February 05, 2005, 04:09:20 PM
There should be 5 screws, one center,
two low by the headlights, and 2 in each
fender on the earlier ones that wrap around
the bottom leading edge on the front fenders
Post by: dwcrisp on February 06, 2005, 01:29:37 AM
On mine (98 tracker 2dr) when I was doing my lift kit I found that there was only one center bolt and the grill snapped out from there without difficulty.  There were no other bolt holes so I am assuming it is only a simple one bolt snap in mount.  If a 98 Sidekick is exactly the same it would be great.  If the dimmensions are exactly the same even if it is a 5 bolt mounting system that would work as I could just screw in additional bolts as needed.  If the shape is way off it might not work.  I noticied on one side the outside edge of the grill locks into the air intake in the fender well.  That could be a factor also.
Anyone tried this?
Post by: droppedtracker on February 06, 2005, 04:21:48 AM
i have a 98 tracker my grile has 1 bolt in the center of the grille but also has 8 plastic clips that the grille snaps into forget the sidekick grille just do what im going to do and thats putting a phantom grille on!!!!!!!!!!!!!!! ;D
Post by: Mikerpm4x4 on February 06, 2005, 01:03:12 PM
I cant picture what the 98 sidekick grill looks like but I have a 97 tracker and I swapped a 94 4 door grill in mine. You would need the bumper also in that case. The grill has a lower lip that the tracker does not. Do you have a pic of the grill you want to install?
Mike
Post by: dwcrisp on February 06, 2005, 01:56:10 PM
mikerpm4X4,  the 98 and 97 are the same grill on a tracker.  An older model with a lower lip as you describe might be a neat swap since I have a gap now that I did a lift (2") and the lip from an older model grill might just be the cool ticket.   how does the older model grill mount?  Did it fit the opening?
Post by: mudfkr on February 06, 2005, 07:26:35 PM
I think you'll find the lip sticks out like this
(http://www.eye-irritant.com/august2004/93escudo.JPG)
and not down so it wouldn't cover the gap from your body lift.
Post by: Mikerpm4x4 on February 07, 2005, 09:06:11 AM
It does fit the opening but I had to drill the upper center hole in a different place. Honestly I cant remember what else I did? :-/ Sorry. I know it can be done... ::)
Mike
Post by: dwcrisp on February 07, 2005, 11:57:57 AM
So it does fit the housings around the lights and into the general opening.   I see what you mean.  If it didnt look right I bet I could grind it down flat if I needed to.
Post by: whitfield on February 07, 2005, 04:43:12 PM
(http://www.zuwharrie.com/gallery/albums/userpics/fall_2004/DSC00146.jpg)
THis is my 1998 Sidekick Grill in my 1994 Sidekick.
Nothing special, no mods.   Just used the center screw and the 2 sides under the fender edge.
My tracker grill looks different.
Post by: HotRod on February 08, 2005, 05:10:48 PM
That looks wicked whitfield;D
