ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: msabmf on June 19, 2006, 08:26:00 PM
Title: broken axels
Post by: msabmf on June 19, 2006, 08:26:00 PM
does any body sell upgrded axel shafts for stock sammy housing besides calmini i break  theres about every 3rd trail i do              THANKS !!!!!!!!!
Title: Re: broken axels
Post by: mrfuelish on June 19, 2006, 09:19:51 PM
spider trax full floaters would be the next Better thing, then trail toughs or skys toyota off set rear ends.
Post by: Maroon Monsoon on June 19, 2006, 10:45:57 PM
do D 44's or a 9 inch or something. if you break your shafts that often get something where you can run a 31 spline axle shaft and a good strong ring, pinion and spider gears.
no use messing around with light stuff if it breaks all the time. if you have leafs it should be moderately easy to weld some perches on some new axles and bolt em on
Post by: zukzilla1662 on June 20, 2006, 08:56:01 AM
how much wider are dana 44 and the 9 rear?
Post by: msabmf on June 20, 2006, 08:21:20 PM
im installing 44s and 4 link this winter but i still want to wheel the rest of the summer so i need axels  till then   thank for the replies though
Post by: joe_and_jeep on June 20, 2006, 08:25:21 PM
If you get a Quadra Trac Jeep Wagoneer (Pre 1980) It will come with a passenger drop D44 and rear passenger drop D44 perfect for the offset in the Sammi case.  Can go down to 5.38 gears and they are roughly 58inches wide.  Ring and pinion are a lot bigger and the shafts are 30spline.
Post by: 1bigtracker on June 21, 2006, 04:58:19 AM
you will keep breaking them then if you already had aftermarket axle shafts.
I can't see blowing the money on a full floater just to swap it out in a few months :-\  unles you want to send it to me after your done.(6in wider than stock plz ;D )
Stu
Post by: the_maplebar on June 21, 2006, 08:47:33 AM
How strong are the axles that come with the Newfields?
http://www.cvunlimited.com/NEWFIELD/suzuki.htm
Post by: SnoFalls on June 21, 2006, 10:06:08 AM
Actually can go to 5.89's, and the front is 60.5" WMS (I forgot the rear ... it might be 58")
Post by: zukzilla1662 on June 23, 2006, 06:38:43 AM
how much wider ar 44 and 9 inch rear on my samurai, how much would the tires stick out gotta keep mine street legal
Post by: Maroon Monsoon on June 24, 2006, 03:49:30 PM
a friend of mine has a 9 inch on his leaf sprung wrangler and he matched it up to his front axle pretty nicely. I don't know if he narrowed it or what vehicle it was off of. if you narrow the axles it gets way spendy for shafts I heard. there is a writeup on a 9 inch in a track/kick and it's off an old bronco and only about 3 inches wider than the front end of that kick if I remember right.
I have no idea avout the 44's. you could always get a narrow offset wheel so the tires wouldn't stick out too bad.. would only work to a point but you know
Post by: Drone637 on June 24, 2006, 07:15:25 PM
What sized tires are being run that you keep snapping axel shafts?
Post by: Maroon Monsoon on June 25, 2006, 12:16:36 AM
a friend of mine always raves about his stupid nissan axles and how they are as strong as dana 60's... we always talk about NAS (nissan axle swap) and ask why people don't NAS F-350's so they can have a beefier axle just to piss him off cause he is full of crap
Post by: msabmf on June 26, 2006, 07:12:16 PM
im running 14" lift with 36" iroks and a detroit locker in the rear and a lincoln locker in front
i have never had an issue in the front i only brake the rear short side shaft
thanks fo the info on the jeep axels i will check to see if the off set will be equall side to side
Post by: msabmf on June 26, 2006, 07:14:12 PM
thats funny my daily driver is an 06 f250 4x4 diesel 4 door short bed its on 37s my sammys only 2" shorter
Post by: Maroon Monsoon on June 28, 2006, 01:58:05 AM
NICE! I want a daily driver like yours. leaning twards an older body style ram 1500 extended cab short box with cummins and manual trans if I had the money
Post by: pcguy on June 28, 2006, 02:23:41 PM
If your using lockers, skip the dana 44 since the drivers side outer u-joints are chronically weak, they fail quite often on jeeps....... put your money in a dana 60 or a ford 9 inch.......
Post by: Drone637 on June 28, 2006, 06:18:56 PM
I thought the newer Jeep 44's had the larger outers on them.
