ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: zukzilla1662 on July 06, 2006, 06:57:14 PM
i have a 1.3 that is stock and i plan on adding
- empi carb
- try y header
- 2'' exhaust
- 5:38 axel gears
will i noticea difference
A solid difference. But what size tires are you running? If you just a little underpowered, I would do the engine mods first, then check to see if you still need the gears.
I'd do the gears first, but that's me :) I like CRAWLING over rocks. You will notice a big difference with mods + Gearing. Gearing will put your engine back into it's intended power range during normal driving.
True, but if you want to crawl, get a 4:1 first. :)
If he is only putting 29" tires on, he may not need to gear that low. My brother was lucky and I just threw my old 410 transfer case under his when he went to the 28.5" tires. ;D
if your only running 31's and dont plan on going up then 5:38's are going to be two steep, 4.62's are perfect for 31's. and then if u wanted u could do T-case gears for added crawl ratio,
the rest will make a difference, I run 2 inch exhaust, weber carb, KN airfilter on stock 1.3, running 31x10.5's all stock gearing and I can run 70mph easy. I do have 4.62's to go in tho...
all the stuff your running will make a difference, but like I said those gears are too steep for 31's and if u plan on running on road, if its just a trail rig, then u fine.
John
i have 32 and want to run 34's
