ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: Jeff@TireBalls on July 19, 2006, 02:42:53 PM
Title: Diagnostics port?
Post by: Jeff@TireBalls on July 19, 2006, 02:42:53 PM
Can anyone tell me where to find the diagnostics port? I just bougt a 2000 GV this weekend and after less than 100 miles the service engine soon light is on.  >:(  I bought a code reader but can't find the port for the life of me.
Title: Re: Diagnostics port?
Post by: AJMBLAZER on July 19, 2006, 03:25:25 PM
Sorta by where your right leg goes as you sit there driving.  The best way to get to it is either kneel on the floor and look up under the dash or lay on your back and look up.  It's sorta tucked up behind the dash plastic.
Post by: Jeff@TireBalls on July 19, 2006, 03:37:07 PM
Great, found it thanks!!!
code 0440  Evaporative Emission System
WTF is that?  ???
Post by: AJMBLAZER on July 19, 2006, 03:44:34 PM
Got a service manual?
Post by: Jeff@TireBalls on July 19, 2006, 03:47:01 PM
Nope, I just bought the GV saturday.
Post by: blacknight on July 19, 2006, 04:53:30 PM
gas cap on tight???
George
Post by: Jeff@TireBalls on July 19, 2006, 05:04:46 PM
Yep, first thing I checked.
Post by: 97TRAKIN on July 19, 2006, 05:07:42 PM
gas cap on tight???
George
My thoughts exactly^.
It seems a bit early for the evaporator to go south. How many miles?
Post by: Jeff@TireBalls on July 19, 2006, 05:48:58 PM
80k
Post by: beerman on July 20, 2006, 09:07:13 PM
that explains why i found a spare plug when we installed the "2WD LOW" kit today :)
Post by: IanL on July 21, 2006, 01:08:50 AM
Glad to hear someone else is using that - I use mine every day, in and out of the garage (it's on a slope).
Post by: beerman on July 21, 2006, 02:09:39 PM
i think the 2wd lo is mandatory when towing a camper, it saver the clutch a lot when driwing in tight spot's ;)
Post by: Jeff@TireBalls on July 21, 2006, 06:27:01 PM
Drove 400 miles today and the light still hasn't come back on.  :)
Post by: 97TRAKIN on July 25, 2006, 02:52:03 PM
Did you change grade or brand of gas? This also causes wierd stuff to go on with the emissions system, rearly but it does happen.
Post by: Jeff@TireBalls on July 25, 2006, 07:09:49 PM
That was the first tank of gas I had put in it so its hard to say. Its still hasn't come back on so is must be one of those pre set deals that automaticly comes on at a certain mileage.
Post by: FNG on July 26, 2006, 07:18:15 AM
 Code 0440 or p0440 is fuel tank vent system- above limit. no change to fuel mixture is seen
when purge valve from canister is opened.If this fault returns pm me and i can give you more
info for diagnosis.
Post by: Jeff@TireBalls on July 26, 2006, 10:07:56 AM
Thanks FNG!!!! So far I've put about 300 miles on it since and it still hasn't returned.
Post by: FNG on July 27, 2006, 05:55:58 AM
Thats good because canister faults can be a pain to find.Was it siting for a while before you bought it?That can cause faults with solenoids sometimes.Hopefully the fault will not return
 ;D
Post by: Jeff@TireBalls on July 27, 2006, 08:00:38 AM
I'm not sure, it was on a car lot. It came on after about 100 miles.
