ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: fullsink18 on July 26, 2006, 06:02:21 AM
Title: Idler Arm Brace
Post by: fullsink18 on July 26, 2006, 06:02:21 AM
Hey Guys, quick question.
Did anybody install the calmini idler arm brace?  When you take the nut off the idler arm there is also a lock washer and a big washer.  When you put the brace on did you reuse the big washer between the brace and arm or did you just use the brace to hold everything up?
Title: Re: Idler Arm Brace
Post by: derekj on July 26, 2006, 10:16:07 PM
i made my own idler brace and if i remember correctly i only used the lock washer as the brace takes the place of the big washer.
derek
Post by: fullsink18 on July 27, 2006, 05:45:04 AM
Thanks, Yeah I am thinking of taking the washer out becuase that brace should hold it up and then the nut would be threaded on better.
