ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: superzooki198806 on July 30, 2006, 09:55:11 AM
Title: 1.6 16v samurai swap wiring need help
Post by: superzooki198806 on July 30, 2006, 09:55:11 AM
i need help trying to get the wiring on my zooki
like with the distributor can any one help
Title: Re: 1.6 16v samurai swap wiring need help
Post by: Rhinoman on July 30, 2006, 01:34:18 PM
There are a couple of different distributors. What does yours look like? how many wires? does it have the coil integrated with the distributor?
Post by: Rhinoman on August 01, 2006, 10:50:48 AM
I've PM'd you but I'll reproduce the info here so it is available to all. On the 3 pin dizzy the white wire is from the ECU, the black/blue is the switched 12V supply from the main relay and the black/green is the ground. I have a 3pin dizzy here, if it is the same as yours can you tell me which wire goes to which pin
James
(http://www.btinternet.com/~j_holland/images/16v_dizzy2.jpg)
Post by: superzooki198806 on August 05, 2006, 07:53:46 PM
the white is on the end blue is in the middle and black is on the left
Post by: Rhinoman on August 06, 2006, 06:09:05 AM
Thank you, thats a big help to me.
