ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: lacrosse10604 on July 30, 2006, 08:29:14 PM
hi. I did the homemade 3" body lift, front strut mount flip and crown vic shocks. I extended the shifters. Now my shifter won't go into 1st, 3rd, and 5th gears. I can get into 2nd, 4th, and reverse.
Any suggestions?
make sure the shifter isnt hitting the body inside the transmission tunnel.
wasthe shifter in neutral when u took it out?
No, its not hitting the body.
It probably was in neutral when I took it out.....but then again I may have moved it into a gear to as I struggled to depress the spring....
