ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: BFM on January 18, 2005, 05:57:49 AM
Title: Noisy valves
Post by: BFM on January 18, 2005, 05:57:49 AM
I've had 2 trackicks both with noisy valves (or sounds like valves) when cold/under load.  Adjustment doesn't really do much.  Any advice based on similar experience?
I'm thinking maybe they are just noisy little engines.  BTW this board kicks ass.  In the last month I've done enough research hear to do my entire build-up (planned but not paid for).
Title: Re: Noisy valves
Post by: Bobzooki on January 18, 2005, 06:21:17 AM
Well, if it sounds like a sewing machine, that's what it's SUPPOSED to sound like!   8)  It could, however, be your fuel pressure regulator.  Hmm, loud when cold...
How's your oil level?  What kind of oil are you using?  You don't happen to have a loose lug-nut, on the left rear wheel do you?  (No, just kidding, that wouldn't be it - OR WOULD IT???)
Post by: BFM on January 18, 2005, 07:03:37 AM
Oil is good, no smoke, power is good (as it gets), engine has 104 km on it.  Just sounds slightly clicky in the top end of the engine.  I was just asking before I spend some money on it.  I want to build-up a solid rig so I thought I'd ask the Zuki B.B. what they thought.
I'm in Toronto and there's a limited zuki following up here.  Wish a new of a 4x4 shop that didn't laugh at zuki's.
Post by: Bobzooki on January 18, 2005, 07:10:46 AM
1.6L?  8-valve or 16 valve?
My 16 valve makes a clicking noise under "just a little" throttle.  It's the fuel pressure regulator.
Post by: ebewley on January 18, 2005, 07:12:59 AM
Is this when the car is in neutral and an accessory is turned on like the lights or heater? The earilier fuel injection systems give a real rat-a-tat-tat sound that is quite loud. This noise will be quite annoying if you have taken off the air box and put on a cone filter. You can make it even louder, for testing purposes, by removing the crossover pipe for the induction.
Another thought is, based on your "under load" statement, that you have a rod knock. If there is no noise / very little noise when your engine is free wheelin but there is considerable noise when your accelerating / pulling something. This could be it.
HTH, Eric
Post by: BFM on January 18, 2005, 07:16:36 AM
It's a 93 with 104 km, no rust.  I bought for 3k Canuk in Toronto.  That's good if you know my market.  8V of coarse.  Everything on this tracker looks near new.
BTW my friend and I figured out the easiest fix for computer failure on the trackick.  We hooked up the fuel injector (TBI) directly to the battery.  No computer/no problem.  Great and easy road side repair even.
Post by: Bobzooki on January 18, 2005, 07:21:50 AM
Oh.  An 8-valve.
I haven't had one of those since I traded in my 91 on a 95.  They DO make roller-rocker arms for the 8-valve, if I remember correctly...
Post by: LilRed on January 18, 2005, 07:37:39 AM
  My 16valve sounds like yours.  Thought it was the valve adjustment but it made no difference.  We're thinking now that it is piston slap.  But its been doing it for 40K+ miles so I don't worry too much.  I have heard of using a heavier (I think!) oil to help but haven't tried it.
Post by: hcgalvin on January 18, 2005, 07:43:52 AM
Noisy valves? Hah. I drive a chimney...
Post by: TN_Tracker on January 18, 2005, 10:40:16 AM
Mine does it, my little brother's does it, they both run great and have well over 100,000 miles on them now.
Post by: explosivo on January 18, 2005, 11:02:27 AM
I don't remember mine making much noise, but then again I got it with a burned exhaust valve, so I didn't drive it too much before the head was redone.
Post by: wildgoody on January 18, 2005, 11:53:15 AM
Piston Slap
I got it, but then again I got 275,000
miles on those pistons too
Post by: speedytang on January 18, 2005, 07:04:26 PM
Switch to 0-20w synthetic for the winter and my noise went away in my wifes 8v engine.
Post by: Bobzooki on January 19, 2005, 12:16:01 AM
What is that, 50% Kerosene, and 50% 5W30?
Never heard of such a light weight oil!  Sounds like...
...sewing machine oil!  And what does a sidekick engine sound like?  A sewing machine!  Makes sense!!!   ;D
Post by: wildgoody on January 19, 2005, 02:41:44 AM
Hey Bob, don't you remember the
Mobil1 coming in 0-50W, I was like  :o
The spread of #s in synthetic oil is
not such a big deal as in conventional
oils, it seems they put microscopic plastic
threads in conventional oil, they roll up
when cold, and unroll when hot to simulate
a thicker oil, even tho it's not, so if you use
conventional oil, you are really using to lower
# in the oil, it just acts thicker when hot.  Best
bet is to use the highest # oil your climate will
(and your engine) tollerate, turbo VW engine
builder Car Craft in Riverside Ca.  recommends
straight 40W in those engines. Multi Grade oil
was invented for your wife, 5 seconds after start
to 50 MPH down the road, poor engine  :'(
Post by: Bobzooki on January 19, 2005, 03:09:05 AM
Multi Grade oil
You KNOW my wife???
More like 0 to 80 in 5 seconds, if she could!!!
Post by: shilly on January 29, 2005, 04:54:46 AM
I got the same noise before and after the valves were adjusted. It goes away after the engine gets up to temperature, so on these cold mornings I just pull it out and let 'er idle while I'm packing my lunch box.  I've tried every oil from 5w-30 synth to 10w-40 dino juice and the sound is the same, winter or summer.  Another one of those weird little things, I guess...
(Almost forgot; '91 8V 1.6 with 137K on the clock, currently using Castrol Extended Wear 10w-40, and it's a non-smoker)
Post by: zookiemike on January 29, 2005, 08:59:26 PM
All my suzuki's sounded like that. Even my one owner 42k 94 tracker ;).
Post by: 90Stomper on January 31, 2005, 01:31:17 PM
mine 90 track 8v, has always sounded like a sewing machine, even with a new motor that had a new head with a calmini cam.  think they just sound that way.  once upon a time i did have a louder intermiten ticking, that was one of the flush philips screws that hold the cam bearing flopping around inside with my rocker arms!!  now thats not good, but also happens to trackers sometimes, so i hear.
Q:  it sounds like you are all saying that thinner oil is better for lifter noise.  then why is Slick 50, which is thick, suposed to help with that too?
