ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: 36zuk on January 23, 2005, 02:19:45 PM
I have the RRO trailblazer kit with 3in springs. My driveshaft is hiting my Transmission xmember how can i get that clearence.
My mates running that same kit in his "90 Sammy and he had to cut the x- member up a bit, not tidy but it works :-/.
Not too much help here, not what I've seen somewhere else :-X :-X ::) ;D
i think rock4xfabrication.com has a high clearance front crossmember if i recall correctly.
shane
Yep we do.. replaces the stock x-member completely. 100% bolt in and allows you to cut the stock x-member out and ours goes up and over the driveshaft allowing as much droop as your shaft can physicaly go.
Is it wide enough to fit a SideKick with a Sammie T-case?
