ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Carnage on September 21, 2006, 12:42:13 PM
Title: Check engine light whenever gas tank if FULL ____?
Post by: Carnage on September 21, 2006, 12:42:13 PM
Another thing with my friends ride,
Whenever she fills up the tank to FULL on her tracker the engine light comes on.
(she does not overfill)
Then maybe when it goes down to about half... it turns off.
(and we both have checked that the cap is properly tightened)
Title: Re: Check engine light whenever gas tank if FULL ____?
Post by: Rhinoman on September 21, 2006, 01:10:20 PM
Have you checked for codes?
Post by: Mike71 on September 25, 2006, 11:09:20 AM
no one will be able to help untill you get the codes read. unless they have had that same problem and had their codes read
Post by: Carnage on September 25, 2006, 11:12:34 AM
well... was wondering if it was a "normal" occurrance
(if anyone else had it and paid it no mind)
Post by: 4njeep on September 25, 2006, 12:02:45 PM
I believe when that happens its actualy a check "wallet" lights. The tracker is just telling you that you got ripped off at the pumps.  ;D
Post by: Carnage on September 25, 2006, 12:27:24 PM
hehe... true dat
Post by: urbanwheeler on September 25, 2006, 11:10:00 PM
Or it might not be enjoying the gas you fed it ;D
Post by: Rhinoman on September 26, 2006, 04:38:29 AM
Only things I can think of are maybe its a problem with the charcoal canister or maybe its an earthing problem
Post by: whitfield on September 27, 2006, 10:53:27 AM
What year?
I just had to replace a FUEL Tank PSi switch on  96 Tracker.  The switch / sensor was bad.
On the OBDII, (As I understand) once the code is set (5 failure occurances) it will hold the code and light the CEL for (Test / No Fail) 50 start cycles.
Post by: Carnage on September 27, 2006, 11:07:18 AM
96
how much was the switch?
Post by: whitfield on September 29, 2006, 06:17:43 AM
Don't remember exactly, But from the dealer it was stupid expensive...
I got mine used from Sean at Aftermarket4x4.com for a very reasonable price.
