ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: TysonS on October 06, 2006, 02:19:36 PM
ok, here is my question.
I don't have a calmini kit and i havn't widened my ifs.
I am running 2 1/4" coil spacers but would like the extra strength and steeper opporating angle to a maximas.
Can I still run the Nissan Maxima cv's following the swap hagen did?
Will I have any clearance issues with the stronger cvs?
Thanks yo ;D
the toyota conversion is easier and uses store bought cv,s not custom. stan
what is involved with the toyota conversion?
you must do the hagen widening some grinding some inner axle mod. stan
is it worth all the work, any writups?
it is worth the work and the kit is well put together i installed mine in july and i run 34s and lockers and have had no problems at all.toy cvs are the way to go
i'm running 16x39.5x15 pitbull rockers & not hav'n problems. ;D stan
is that with a alloy housing ;D ???
Stans toy kit is the way to go. Almost every trackick in the Rpm club is running the toy kit. It works very well. I have it in the rockstar with 39.5 pitbulls also, chunk with 37 MTRs, blake also 37 MTRs , Stu 36 Irocks....... Dan...ECT you get the point.
Any pics of the toy's kit?
Fredo
Fredo
I had pics of it but my computer recently crashed from power problems and I lost everything. I think there was a thread with some pics. i will see if I can find it.
Mike
http://www.zukiworld.com/forum/index.php?topic=9229.0
Found it. The begining has red Xs but the end of the topic has installed pics
[url]http://www.zukiworld.com/forum/index.php?topic=9229.0[/url]
Thank you very much Mike!
Fredo
how much more lift can be safely run with these cv's?
the kit is not for getting more lift but for cv strength. but if your good at fabing anything is possible i'm run'n 39.5" tires, might go bigger after new mods. ;D ;D stan
thanks, i wasn't sure if these CV's could operate safely at steeper angles or not. i'm not good at fabbing.. i really have no plans to ever go bigger than 32x10.5
