ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: pragsy on January 10, 2005, 01:56:25 PM
Title: more power
Post by: pragsy on January 10, 2005, 01:56:25 PM
I know this has been talked about tones on this forum but I'm very curious. I keep seeing these power mods that plug into the computer. Do any of them work..at all or is this just a  big scam. THey are all over ebay. some are obviously a joke. I'm sure I would have herd about it if you really could get 20 horspower from a 5.00$ preformance chip. But other say 8 to 10 horspower. Has anyone tried one?
Title: Re: more power
Post by: wildgoody on January 10, 2005, 02:05:17 PM
It's all BS
Run Away
Post by: adamd on January 10, 2005, 02:11:11 PM
Did u all see that sewing machine/dirt devil vac motor that's hooked up to a faux K&N Filter? They call it a supercharger  ::)
Post by: mrfuelish on January 10, 2005, 04:59:28 PM
The 12 volt hair dryer works better, plus on a cold day you can pre heat and dry your hair while defrosting your windows at the same time. ;D
Post by: pragsy on January 19, 2005, 11:20:41 AM
Thanks for the info. I strongly recomend the under drive pully, mid range cam and 2.25 muffler. they all did a noticable difference for me and my 1.6 16valve 4door.
Post by: cj on January 19, 2005, 12:21:09 PM
Mid range cam? The only cam I know about for a 16v 1.6 is the Hawk and I was told that it was more of a bottom end cam and that they hadn't had good success in developing a mid range cam. What is yours and how does its power delivery differ from stock through the rev range and what sort of increase have you seen?
Post by: Speedracer7c on January 19, 2005, 12:59:22 PM
Where did you find an underdrive pulley?
Post by: mahimahimo on January 19, 2005, 06:27:13 PM
rocky road makes one..... i was looken into getten it but i heard since i have an 8 valve it isnt good cause it will runa little hotter or somehtin alond those lines.....
                                                       -mo
Post by: Bobzooki on January 20, 2005, 12:41:51 AM
No they don't.
Rotational Dynamics made those pulleys, and they've quit making them, so it's hard to say how long they'll last.  (By the way, Rotational Dynamics is just one guy.)
Post by: 3wheelerdude on January 20, 2005, 10:38:44 AM
will the 2.25 exhaust reduce the low end torque. My kick already gets is torque pretty high, I dont feel like revving even higher.
Post by: cj on January 20, 2005, 02:05:05 PM
I was a little concerned about losing any bottom end when opening up the exhaust on my 16v 1.6 4dr. I've just fitted a Tri-Y header and 2" cat back with a a single hi-flow muffler. It's all good. No major gains but it does pull a little harder and has slightly better throttle response. No increase in noise but there is a different, slightly throatier note in the 2-3000rpm range.
Post by: lil_Truck on January 20, 2005, 11:18:28 PM
"but there is a different, slightly throatier note in the 2-3000rpm range."
;D
Post by: Bobzooki on January 21, 2005, 12:50:09 AM
When you take the stock intake components out of the fender (one of which is called the "boom bottle"), and install a snorkel, you'll notice the "throatiness" peaks around 3300 rpm on the 1.6/16.
Post by: cj on January 21, 2005, 05:40:55 AM
When I fitted my snorkel I didn't notice any real change in noise and no difference if the window is up.
Post by: mudfkr on January 21, 2005, 07:29:57 AM
Bob probably notices it more  as he sits on the WRONG side of the trucklet while driving  ;D
Post by: Bobzooki on January 21, 2005, 08:03:33 AM
I wouldn't say WRONG, just more interesting!
Good point - I forget you guys sit on the right side - but the "other" side isn't "wrong", just "left"...   :P
Post by: mudfkr on January 21, 2005, 08:41:28 AM
My point exactly  :P
If every body doesn't stop posting pixs of Moab I might have to make the looonnnnnggggggg journey to Moab in 2006 to check out this backward arrangement of controls you guys have got  ;D
Post by: SnoFalls on January 21, 2005, 08:56:57 AM
to hijak this thread even further ...
On my vacation, I was in the BVI (british virgin islands). I saw more suzuki based trucklets than you can imagine (I'd guestimate 60% of the vehicles were trac/kics or sami's and a few I'd only seen pics of from the zuki web site).
Funniest thing was being the BRITISH virgin islands, traffic drove on the right hand side of the road, but hardly any vehicles were RHD ... a few were, but MOST were not ...
