ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: outdoordog on October 14, 2006, 01:51:36 PM
My sidekick (93) idles REALLY rough. It also blows a smoke at startup. I have done some fiddleing around adn I think the injector on my #3 (third from the front) cylinder is junk. Here is why. I Pulled the plug wires one at a time and the only one that didn't make the idle worse when it was off was the #3. I pulled the plug and it was soaked with fuel. I switched the plug with another cylinder and the plug worked fine in the other cylinder. I switched the plug wire with another cylinder and it worked fine. So not the plug or the wire. I pulled the distributor cap (5 months old) and there didn't seem to be anything wrong there. So with it all put back together when I just let it sit and idle the idle gets rougher and rougher until it starts to put out a substantial white cloud of unburnt fuel. So I pulled the wire from the injector. I am still getting the rough idle (obviously) and the smoke (and stink) of the unburnt fuel isn't as bad but still happens. So here is the question: is the #3 injector bad or do I have another problem?
Thanks.
