ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: 4x4tracker on October 17, 2006, 08:15:58 PM
i have a 94 tracker with a 2" calmini lift and i'm looking at some used rims and wondering
if they will work backspacing and everything
Rock Crawler Series 88
Size: 15 X 8 Bolt Pattern: 5-5.5
Back Spacing: 3.75 Finish: Chrome
yeah they will fit but you may need to do some fender triming to run 30" and up tires or they may rub at full flex...
The rims will fit just fine, but whatever size tires you decide on will determine if they rub. That is the exact same rim measurements I have run on my trucks. One with 2" BL and 1.5" coil spacers with 31" swampers and the other truck has 4"BL, 2" suspension lift and 33" Swampers...
thanks runing 235-75-15's
Those should work just fine then. 8)
thanks again
