ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: rocktracks on October 21, 2006, 07:19:27 AM
I would like to know if anybody had any luck on elminating the slip yoke inside the trac/kick t-cases I have a 89 tin top and I am putting toy axles in it with leafs.I know you can go to ott to get there kicker 2 setup to run a toy t-case behind yours but I would be looking close to a grand for this set up. any help would be great.I have the lower t-case gears already and mine is a two door.That's why I would like to stay with a single t-case to cut down on the drive angle in the back.If you have any pictures can you e-mail me them at pat.courchesne|removethispart|@sympatico.ca thanks you in advance ;D
ihave done it on a tracker i built its not to difficult with the right equip. stan
how did you make it stan and is it holding up
i machined out the shaft & threaded it so i could bolt on the yolk. it's working great. stan
i drilled and tapped the output shafts front and rear and made custom flanges that welded on to my stock slip yokes
