ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: 3wheelerdude on January 16, 2005, 08:52:05 AM
Title: Front hubs are frozen
Post by: 3wheelerdude on January 16, 2005, 08:52:05 AM
Can I leave my front hubs locked in the LOCK position all winter or will it damage anything. I went in water while it was warmer outside and now that its cold again they are frozen. The 4x4 works great, and they unlock from inside but I cant get the hubs to turn to the FREE position, and dont need to neither....
Title: Re: Front hubs are frozen
Post by: MB on January 16, 2005, 09:14:07 AM
It shouldn't hurt to run with em locked, as that has been a post here many times. But on the other hand if your hubs are full of water and frozen... I'd get them apart and cleaned up  and repacked as soon as possible.
Post by: mahimahimo on January 16, 2005, 09:58:34 AM
so u can run wit locked hubs in 2wd and its alright nothing will happen? so technically if thats the case whats better auto locking hubs or manual locking hubs?
                                 -mo
Post by: 3wheelerdude on January 16, 2005, 10:07:27 AM
well i know it will increase my fuel consumption, but if nothing will get damaged if i run with them locked until spring then....
Post by: wildgoody on January 16, 2005, 10:08:53 AM
Autos are junk, I took one apart today,
I don't think Asine (sp) makes them, I
think sombody else does, they don't even
have the cone bolts
Post by: 3wheelerdude on January 16, 2005, 10:12:19 AM
have the cone bolts
but can manual ones stand to stay locked for a few months with no futher damages other than fuel consumption?
Post by: wildgoody on January 16, 2005, 10:23:59 AM
yes, I forgot about mine once for like 3 months,
went to go wheeling and surprise, they were locked
Post by: 3wheelerdude on January 16, 2005, 10:29:55 AM
and.....??......were they damaged or any signs of misuse?? or was everthing ok?
Post by: Real_Red_Sammi on January 16, 2005, 10:30:23 AM
   Use a hammer and a punch, that's what I do ;D!!!
   Make It Hert!!!
   LMS!!!
Post by: 3wheelerdude on January 16, 2005, 10:31:02 AM
   Make It Hert!!!
   LMS!!!
NO THANK YOU
Post by: wildgoody on January 16, 2005, 10:39:30 AM
How should I know, that was 10 years and 200,000
miles ago  ;D  same hubs still, so I would say  OK
Post by: CBTracker on January 16, 2005, 01:14:10 PM
I always lock my hubs when there's snow on the ground, it says in the suzuki manual it's ok to leave them locked with the transfer case in 2wd. but dont' leave the transfercase in 4wd without the hubs locked or run in 4wd on dry asphault. SO. in short the only thing that it'll damage is gas milage and maybe alittle extra wear but nothing major. I would repack those hubs though if their frozen. it's a pretty simple procedure. I repacked mine with high quality axle grease. as long as the grease has a good temperature rating and it NOT long strand grease it should be fine.
-Mike
Post by: lil_Truck on January 16, 2005, 02:22:16 PM
If you go on a good drive down the highway (60mph for 20 min).  The wheel bearing will warm up and melt the ice.
When you get where your going, you can unlock the hubs.  If you wait they might freeze up.
Post by: trialspro on January 16, 2005, 06:57:22 PM
i used to have to hit mine with a rock to get them to turn on my 89 sidekick :P although freezing wasnt the problem
i pulled the bad side off, cleaned it up a little bit and sprayed wd40 in there... PROBABLY not the right way to do it, but it worked out for me
thats my tip, and in my opinion auto hubs suck, and so do pushbutton 4wds... manual stuff re-assures u that your t-case IS in 4wd, and that it WILL be transferred to the front wheels... plus u gotta be pretty lazy to need the auto stuff
too many hassles
ive typed enough though
Andrew
Post by: Rhinoman on January 16, 2005, 08:07:33 PM
i and so do pushbutton 4wds... manual stuff re-assures u that your t-case IS in 4wd, and that it WILL be transferred to the front wheels...
On the Jimny the 4wd light won't come on unless you are in 4wd, you still have the switches on the tcase itself. The pushbutton locks the hubs at the same time so you can't forget to engage the hubs - I suspect we've all done that  ::). Its an air system and if the pressure doesn't hold up then the 4wd light flashes to warn you. You don't get that with a frozen/siezed manual hub  ;D ;D
On the Vit my manual hubs are permanently engaged since one broke. They're not Aisin either - they're marked made in USA, I have heard that they are made by Warn.
Post by: 3wheelerdude on January 16, 2005, 11:02:25 PM
-Mike
You say its a pretty simple procedure to repack with grease. Do you have a walk through? Im at my begining with 4x4 vehicles and not sure how to do this.
Post by: Bobzooki on January 17, 2005, 12:09:40 AM
I threw out my auto hubs on my trail rig, and went to Warn Premium hubs.  They have this cool feature (optional) called a HUB FUSE.  The idea is, when you push it too hard, instead of breaking a CV joint, or a Ring Gear, or Pinion Gear, the hub fuse disintegrates.
The fuses cost about $20 for two of them, and you can replace them without removing the wheel, in about 15 minutes or less.
HOWEVER:  If you switch to Warn Premium Hubs, you WILL have a problem with hub bolts backing out (yes, even with Loctite on 'em).  SO - to overcome this, you ALSO install Spidertrax Super Hub Bolt Kit:  http://www.spidertrax.com/drivetrain_shb.htm
Post by: CBTracker on January 17, 2005, 12:51:45 AM
I recommend getting a service manual from Walmart or Canadian Tire. I have a Chiltons but Haynes is just as good. there are others too. very handy.
Well, I repacked mine in the garage (or in the driveway if that's all you got) with some allan keys, and socket set, some rags and a floorjack.I'll try to remember all the details, if I"m wrong someone here will point it out.
1) jack the suckerup , use some axle stands - much safer.
2) take wheel lugs off and remove the tire and the plastic ring that fits around the metal part of the hub, that just slides off.
3)remove the 6 allen bolts from the face of the hub, be careful of the gasket, you should probably replace it everytime you open it but I didn't cus mine was in good shape.
4) remove the six(or less?) bolts around the outside of the hub casing. This removes the hub from the truck itself.
IF you look around (especially at the Warn fused hubs) you can get an idea of how these things fit together. from the outside of the truck in heres how it goes on manual hubs.
outside cap - this has the allankey bolts in it.
free-lock switch- this is the rotating selector switch   visible from the outside that you use to change from free to lock.
spring - this sits beween the free-lock switch and the spring seat to hold the seat firm against the guide notches on the shaft of the freelock switch.
spring seat - little metal ring with prongs that sits on the clutch (fuse if it's a fused hub)
clutch(or fuse) - round cog looking piece that slides and acutally engages the hub casing(and subsequently the wheel that it's bolted to.) to the axle itself.
After you get a good idea of what's going on, you can take apart each piece laying them on a clean surface in order as not to forget how they go together! after cleaning each one indiviually and giving them a nice healthy coat of axle grease ( any will do, just check out the temperature ratings, and make sure it's not long strand grease as it will clog up the hub) you can start assembling. I wouldn't use WD-40 as it displaces any other types of grease then evaporates leaving the metal unprotected.
You can start to reasemble but be careful that you allign the groves in the hub casing, spring seat, clutch(orfuse). also note that the spring has to be compressed and placed between the lock-free switch and the spring seat ring that must be "hooked" into the lock-free switch's shaft. make sure that you do all of this in the FREE Position with the clutch pulled towards the outside of the vehicle.
The six bolts tighten to 25Nm or 159inch lbs and the allenkey bolts tighten to 12Nm or 106 inch lbs.
Finally test to make sure everything works smoothly when put back together before driving it down the road.
I hope this helps a little, pick up one of those manuals. I think they're like 12bucks or something.  Good luck, just go slow and think it over. it's not that complicated.
Post by: 3wheelerdude on January 17, 2005, 01:56:47 AM
Thank you!
